What can I add to Polk M10?
bears
bears Posts: 4
edited December 2006 in Speakers
Friend gave me a new pair of M10's. Thought I would add a center speaker and a sub. Considered a CSi3 and a PSW10. Anyone have any other suggestions? Really would appreciate the help..
Post edited by bears on
  • danger boy
    danger boy Posts: 15,722
    are you wanting to use them in a home theater set up? if so.. adding a center and sub is important. YOu may want to go instead with a larger center. such as a CSi5. or the Monitor 10's may overpower the smaller center.
    PolkFest 2012, who's going>?
  • tommyboy
    tommyboy Posts: 1,414
    I think he might be talking about these...
    http://www.polkaudio.com/homeaudio/products/m10/
    but not sure, need more details...
    AVR: H/K AVR240
    Fronts: Monitor 50s
    Center: CSI3
    surrounds: R15s
    Sub:Velodyne DPS10
    Dvd/Cd: Samsung HD upconverter (for now)
    TV: 50" Sammy Plasma
    game hardware: 360 and gcn.
    Gamertag: kovster27
  • danger boy
    ahhh ok. never mind then. continue as you were. :)
  • MSALLA
    MSALLA Posts: 1,602
    How big is the room? CS-1 and a psw 202 maybe. No one on here seems to like the psw 10. I've never had one so I can't really say. I do have a cs-1 though. It was too small for my room (12 x 25) but may be ok for a smaller room.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • RuSsMaN
    RuSsMaN Posts: 17,985
    CSR or CSi25 would be the best match. If you are going to run 6.1, pick up another pair of M10's - one for front center, one for rear.
    Any Polk sub would be a good match.
    Cheers,
    Russ
  • bears
    bears Posts: 4
    More info: room size is 10x12.. spare room converted to my "play room"... Will use mainly for Xbox 360 on a 32" LCD HDTV...5.1 receiver is Sony STR-DE835.The m10's are ok but i think that using a good center will make all of the difference..The psw10 has good reviews and will pick up majority of bass..will probably add rears at a later date. Right now i want speakers that are compatible.
  • dipiazza
    dipiazza Posts: 363
    You would probably do better with a psw303, its pretty solid for the price and would go with your M10s. Center try wat russ has said. Get a CSR and anoter pair of M10s for surrounds. Decent 5.1 for games and movies in a room that small.
    Good luck!
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Reciever: Pioneer VSX-D914
    HD-DVD Player: Toshiba HD-A2
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    Subwoofer: SVS 20-39PCi
    2CH Setup
    Integrated: Onix SP3 Tube
    CD Player: Sony CDP-CX355
    Speakers: Onix Strata Mini in PR Finish
    Signal Cable: Classic Speaker, Analog 1 IC
    Headphones
    Grado SR 60, Bang & Olufsen A8, Shure e3
    Other Stuff in Use
    Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
