Box requirement
v850t5r
I just purchased new momo 12-4 and was wondering about the enclosure requirements. The volume requirements from polk says: 0.88 cube for an optimum sealed enclosure.
question:
Does the internal volume of the enclosure need to be 0.88 cube WITH or WITHOUT the sub installed?
Thanks for the input !
question:
Post edited by v850t5r on
.88 is after displacement...wich means..after the sub is mounted. In the spec sheet...it should tell you the displacement of your sub.. just take the .88+ sub dispalcement + any bracing..and that is what size you need
good luck:cool:
