FS: AQ Type 4 speaker cables
Early B.
I have an 8 ft. pair of Audioquest Type 4 speaker cables with bananas in great condition that I'll let go for $80 plus shipping. PayPal preferred. PM me if interested.
There's a pic in the WTB section where I erroneously posted this sale.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
I call dibs, let me check out specs and how much they are new - but consider them sold...
Money order good?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Hey Brad,
What kind of nanners are on those things? And how are they connected by?
Thanks- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Yeah, money order is fine. Those are the nanners you'll find on AQ's higher end cables. I got the same bananas on my CV-8's ($675 retail). I believe they are connected by two screws and they can be changed out to similar AQ spades. They were factory terminated.
Glad you're grabbin' 'em, Sid. These will work very well for the Tylers.
CORRECTION: After checking them again, these bananas aren't connected to the cables by screws, but they look and fit just like the bananas on my CV-8's.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I got your address... just let me know what shipping is and Ill send this out to you................................................ Monday or Tuesday
The Nanners looked good, almost to the point where they could be really good - or the opposite, but I figured Id ask because you always use good stuff... haha - I like buying from you... way to painless...
Thanks again man
I needed some speaker cables in the higher end range... very cool.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Atta boy....Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Hey Brad,
What are the shipping prices to 28023 on those cables?
Thanks...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Just add $5.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
slight delay... will send out MO tommorow, around 4pmish- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Sid --
Got your MO today. Cables will ship on Monday.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Thanks for the update Early...
Just now saw this...
Looking forwards to getting them...
Will let you know when they arrive...
What were you replacing these with?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I consolidated my HT and 2-channel systems, so I don't need these anymore. I'm using AQ CV-8's with DBS.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
