400w to an MM124
Systems
Will it be enough?
Testing
Testing
Testing
Testing
Testing
im planning to setup 2 12 inchers powered by a kicker amp, it's 400w x 2 at 4ohms.Testing
Testing
Testing -
kicker rates its amps at 13.8 volts (basically the car running with sufficient alternator power) -- so that is a "true" 400 watts. if you're doing the subs in proper sealed boxes (0.88 cubic each -- do separate chambers if you can) then you're underpowering them a little but you should be ok -- not great, but ok. just dont try to over juice them and then blow the subs due to distortion.The Artist formerly known as PoweredByDodge
