Kicker ZX250.2
2002tahoe
would this be a good amp to power a pair of MMC6500? (Kicker ZX250.2)
thanx
thanx
2002 Chevrolet Tahoe Z71 4x4:
Kicker ZX250.2
Polk MMC6500
Pioneer TS-A1681R
Dual Kicker 05CVR124
X-File XR8002
Kicker ZX250.2
Polk MMC6500
Pioneer TS-A1681R
X-File XR8002
Post edited by 2002tahoe on
I have the MMC6500's! Im running them off the C400.4 and boy do they sound good.
Im Bi amping them off the C400.4. That way I would not have to use the passive crossovers for better sound quality.
Plus you have the pre EQ button on the momo amp, so you don't have to try and figure out the crossover points. -
I think that amp would do a good job. Kicker makes good gear. I ran some of their amps for a long time.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
To get the best sound of the SR6500 do you recommend to biamp them? on a scale of 1 to 10. If 10 was best possible sound of the sr6500, what would be possible without biamping?
Simply biamping them wont automatically give you the best sound. What it will do is give you the best flexibility in tuning them. In fact when you first biamp them and turn em on, they sound like crap until you get the tweeter level dialed in.
If youre wanting a simple plug and play option then stick with the straight wiring. But if youre going to want to be able to tune them as much as possible then you should biamp.polkaudio sound quality competitor since 2005
