Pioneer HU Repair
spackelman
spackelman Posts: 31
edited November 2006 in Car Audio & Electronics
If anybody can help
Have a pioneer deh-p960mp head unit (the face folds down to reveal the oel dispaly and function buttons). Installed the unit about 18 months ago. Has been working great until recently.
When I hit the "open" button to flip down the face, the unit turns off and the face folds up and down repeatedly until I hit the "reset " button. With the face closed, the unit does work (radio and CD).
If anyone has any info on this hu and this particular problem, all would be appreciated.
Paid about $450.00 for this and it does sound great. I do have a 2 year warrenty which I might have to utilize.
I figured out what the problem is. There is a flat type wire, (13 leads) that connects the face plate carrying frame to the unit. The face plate is connected to the carrying frame. When in the folded (closed position) this connector is folded like a piece of paper in half. I could "wiggle" this connector during the face plate oscillations and it would stop.
Upon closer inspection, you can see the insulation has worn off at the 'bend" in the connector.
Simply, its a bad design. How often can you bend a paper thin copper conductor in half before it breaks. Everytime the face plate would open - it was another bend.
Does anyone have access to Pioneer part numbers??
Thanks again.
Post edited by spackelman on
  • spackelman
  • spwuinmk67
    spwuinmk67 Posts: 797
    One quick point, we can't answer everything within 15 minutes, so there is no need to bump something after such a short period of time. But try calling up pioneer directly. If it's under warrenty, they should fix or replace it. I do believe on their website is a list of parts though for each headunit. www.pioneerelectronics.com
    1993 Ford Ranger super cab:
    Pioneer Premier DEH-P880PRS
    MB Quart QSD216
    in need of amps and subs
    Home:
    52" Sharp Aquos
    PolkAudio Monitor 10's
    Harmon Kardon HK3375
    Xbox 360
    PolkAudio XM tuner
    Owner and co-designer of www.basicholdem.com
  • 1996blackmax
    1996blackmax Posts: 2,436
    Well put.....if it's under warranty have them fix it.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • spackelman
    Yea, I know, but the mr. fix it side of me is saying "you can do this".
    Pioneer does list some parts, but not the ribbon connector.
  • spwuinmk67
    Being mr. fix it is all fine and dandy. But why pay for it and waste the effort if they can handle all the hassle? Plus, even opening the unit yourself will void any warrenty. You've got another what, 6 months, of the warrenty left? Use it, be mr. fix it when they're not gonna pay for it.
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • spackelman
    Thats a big 10-4
  • spwuinmk67
    Out of curiosity, where in central Jersey are you?
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • spackelman
    Exit 117 off the parkway (keyport area)
  • exalted512
    exalted512 Posts: 10,734
    only in new jersey can you say something like that and everyone knows where it is...
    -Cody
  • audiobliss
    audiobliss Posts: 12,518
    Glad to hear I shouldn't feel too stupid to have no clue what that means...
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • spackelman
    Its a Jersey thing - we are all stupid...
  • 1996blackmax
    One of my good friends is from Jersey..... pretty sharp guy actually.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • spwuinmk67
    I'm off either exit 80, or 77, depends on which way you wanna go. I have a few friends near you.
    New Jersey consists of 3 roads to worry about. The Garden State Parkway, the New Jersey Turnpike, and the Atlantic City expressway. You can tell what kind of person someone is by the exit they live off of, kinda funny actually.
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • spackelman
    I'm afraid to ask, but here it goes -
    OK exit 117 - What does that tell you?? I also met my wife off of 117.
  • spackelman
    To update, I pulled the pioneer hu and put the original delco back in my truck (2002 Silverado, 2500HD crew cab).
    I e-mailed pioneer and got a resoponse that I will be contacted. Will them call on monday. The delco actually does't sound bad with my polks.
  • spwuinmk67
    I don't know all areas of jersey that well, but I can do a little closer to me better. Like my area, lot of rednecks. Exits 81-83, Toms River, is a lot of people who like to think they're ghetto. Also there's a noticeable difference in wealth between each of the three exits. People south of me, and in the 609 area code, are all just a little weird. And just about anyone near that can tell you that. Oh, and if you want easy girls, head to Lacey township/Forked River area.
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
