Trying to update my system showcase
Systems
Systems Posts: 14,873
edited January 2007 in The Clubhouse
Hello
I've been trying to update my system today and haven't had much luck. Every time I try and upload a picture it gives me this error message:
File format image/jpeg invalid! You can only upload JPEGs!
Well the picture is a jpeg, its under 2 mb's, and its 800x600.
Any ideas?
Testing
Testing
Testing
  • TheReaper
    TheReaper Posts: 636
    edited November 2006
    Are you using Internet Explorer? I think the System Showcase only likes IE.
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • Systems
    Well no, actually I was using Firefox. I'll give it a try in IE
    Testing
    Testing
    Testing
  • phipiper10
    phipiper10 Posts: 961
    edited January 2007
    Aaaah, was having the same problem. God bless searching these forums!
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • phipiper10
    edited January 2007
    IE resolved the problem. Thanks!
