the most powerful subwoofer?
MysteriousGT1
I think this is the most powerful one, at least it is crazy high in watts!
15,000 Watts Peak
7000 Watts RMS each coil
Over 4" long throw excursion
Dual (2x1ohms) 4" x 8" High Temp military grade flat wire voice coil.
(4)Quad Nomax / Romax spider construction
8 gauge speaker connections
112lbs.
can you imagine the punch this speaker packs?
i cant imagine this thing being installed in a car!
15,000 Watts Peak
112lbs.
Troy: 2004 Hyundai Sonata V6
Polk/Momo MMC6500 Components (fronts)
Polk/Momo MMC690 Coaxiels (Rear Deck)
Polk/Momo 400.4 4 Channel Amp....More to come!
Post edited by MysteriousGT1 on
112 lbs?! jesus lord. where would you put that thing? looks like the bomb in that movie armeggedon.At Home:
Panasonic 42'' TC-L42U12 LCD
Pioneer VSX-80TXV
Toshiba HD-XA2
Sony PS3 - psn "metalguitars"
Xbox 360 - gamertag "giggidygiggidy"
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Martin Logan Dynamo (x2)
Audioquest interconnects and wires.
Away From Home:
JVC HDR-50
stock system in new car for now:( -
I ran some of their gear back in high school. My car back then was definately way louder than it is now ........
Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
1993 Ford Ranger super cab:
Pioneer Premier DEH-P880PRS
MB Quart QSD216
in need of amps and subs
Home:
52" Sharp Aquos
PolkAudio Monitor 10's
Harmon Kardon HK3375
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com -
I think I would rather have this http://www.tcsounds.com/lms5400.htm . The version without the linear motor is suposed to be about 3db louder.
it isn't the most power handling sub in the world, but the gti series from jbl are deadly. i had a good friend we put two w15gti with a bpx2200 on each sub in a 96 blazer. we blew the 2 in. thick mdf box apart, and we secured the box together with bolts. it also spidered the back glass. by the way, i do have 2 w10gti's, a bpx1100.1, a gto 75.4, and a set of p953's and p650c's for sale. it's product matched and i'm askin 1600.00 for it all. all brand new just in case someone's interested.....
I think this sub might be a little bit bigger. Like a 60" sub. The motor is capable of producing 6,000+ pounds of linear force. And it also ballooned the walls of a bread truck.
http://www.thetechzone.com/photo/computers.php?photo=13813 -
I remember seeing that a while back.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
Thats a crazy sub! Too bad its not realistic...1997 Toyota Supra TT
1993 Honda Civic K20 swap
2004 Honda Pilot EX
I WANT TO BUY: -
that 60" one would problem throw a large male a couple feet.
