Been a while, components and amplifier hookup question
kenstewart
Been a long time since I've posted, but you guys have been the most reliable car audio buffs I've come across. Hope you don't mind me asking this question.
I had the momo 5250s in my truck, but recently got a deal on some Image Dynamics Chameleons (CXS54s) to match my two Image Dynamics subs. The crossovers for the momos had two amplifier channel connections each so I utilized all four channels of my MTX Thunder 684 amp. Now, the Image Dynamics crossovers only utilize one amplifier channel each. So, now I have these awesome speakers that sound like crap because I'm not feeding them enough power. Here are the specs for the amp and the speakers:
Speakers:
100watt RMS @ 4 ohms
Amp: at 4 ohms
@12.5 volts:
60wattsx4 ... 240wattsx2 bridged
@14.4 volts:
85wattsx4 ... 340wattsx2 bridged
Ok, so it's too powerful bridged (or is it?), so my question is can I dump the ID crossovers and run directly from amp to speakers? Do I lose any fidelity by dumping the ID crossovers and utilizing the MTX amp crossovers?
BTW, still keeping the Momos and putting them in my son's Mustang
Speakers:
Amp: at 4 ohms
@12.5 volts:
@14.4 volts:
Eclipse CD8445 HU
Image Dynamics CXS54 Chameleons component setup
Two 8" Image Dynamics ID8D2v.3 subs
MTX MXA6001 amp for subs
MTX MXA3002 2-channel amp for comps
Accumat and Peel-n-Seal
Stinger and Knukoncpetz wiring
Post edited by kenstewart on
You will not lose fidelity.... the only thing is the MTX's crossover will not give you high enough crossover points as they only go up to 200HZ. You will run in to the same thing with your HU. Your tweeter will get fried.
Those MTX amps give you more power than those specs, so that amp is probably giving somewhere around 80 solid watts or so. I woul think that this would be enough power to make them sound good. I am running 90 watts RMS to my Rainbows, and i think they sound very nice with that power. They are also rated for 100 watts. I had the amplifier model below yours and the birth sheet said it gave me a little over 30% more power than the posted ratings. If you bridge the amp you will be getting around 300 watts per channel. You may need to move another amp.... You could try bridging the amp and setting the gains to their minimum rating and see how that goes, but be very careful with the volume knob.
Seeing that you have a CD8445, I would get the microphone if you do not already have one to help you tune your system. This feature comes in very handy. Sounddomain has it for $20 dollars.... http://www.cardomain.com/item/ECLMEI100Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
Actually, I remembered I had another new MTX amp, MXA3002 2-channel amp. It's 75x2 @ 4ohms. Looks like my solution, then I can pull the Thunder 684 and put it in my son's stang running the Momos. Not the full 100RMS, but I know the MTXs underrate their amps, so it should be kicking out at least 80/85 RMS so I should be good to go right?
Oh, forgot ... my HU has 8V preouts, any prob since the MXA3002 says it takes 5V preouts max input signal? Must not have been since my sub amp says the same, but my previous comp amp (Thunder 684) said it took up to 8V signal.Eclipse CD8445 HU
Stinger and Knukoncpetz wiring -
That rating is an RMS rating, you'll be fine. I actually contacted Arc Audio about this before. My CD7000 has 5V preouts, and my two previous Eclipse units had 8v preouts. I was running them with my Arc amps which have a rating of 250mV - 2.5V with no problems.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
Thanks for the info
Eclipse CD8445 HU
no problem
Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
my HU has a 2.5 volt pre-out. is that horrific? when i switched from my stock HU to a Pioner DEH3800 i lost a lot of bass. is this because i am running it from the HU instead of a Hi to Lo converter from a speaker?2002 Chevrolet Tahoe Z71 4x4:
Kicker ZX250.2
Polk MMC6500
Pioneer TS-A1681R
Dual Kicker 05CVR124
X-File XR8002 -
2002tahoe wrote:my HU has a 2.5 volt pre-out. is that horrific? when i switched from my stock HU to a Pioner DEH3800 i lost a lot of bass. is this because i am running it from the HU instead of a Hi to Lo converter from a speaker?
That doesnt sound right unless your stock HU had a pre-set EQ to ramp up the bass.polkaudio sound quality competitor since 2005
its a stock AC delco unit from GM for a 2002 Tahoe. would it be because i have crappy rca cables?2002 Chevrolet Tahoe Z71 4x4:
Kicker ZX250.2
Polk MMC6500
Pioneer TS-A1681R
X-File XR8002 -
BTW, congrats Mac on your win. You gave me tons of good advice when I first set up my system, glad to see you win
Eclipse CD8445 HU
