Polk rti & Yamaha
bignorm
Hello
quick question
I have the Yamaha RX-V1300 receiver with a selectable ohm switch. I currently have the switch set to 8 ohms.
Is this correct as I noticed the Rti series CSi series FX series
all indicate "4 ohms nominal" on their spec sheets.
The Yamaha other ohm switch setting is a combination of different
ohms (not sure but something like 4 ohms front 6 ohms rear etc)
Thanks for the help!!!!!
quick question
Eliab/Dave Abrams calibrated Panny
Yamaha,Denon,Toshiba "in the rack"
Polks all around
SVS on the floor
Polks all around
SVS on the floor
Post edited by bignorm on
NORM!
I believe that all of your speaks are 8 ohm, I'd say set it at 8 and let 'em rip.
Are you sure?
The owners manual for the RTi FXi and the CSi all indicate
"4 ohms nominal"Eliab/Dave Abrams calibrated Panny
Polks all around
SVS on the floor -
The online manual shows 8 ohm. That's what I've always ran mine at anyway.
NOOOOOOOOOOOORM!
The are designed to be used with HT receivers which most are designed to deal best with 8 ohm loads. Check with customer service, though, they may be able to shed a little more light though.
Thanks all
I checked online and my speakers are all 8 ohms
must have incorrect manualsEliab/Dave Abrams calibrated Panny
Polks all around
SVS on the floor -
It's amazing how documentation, in a field where technical setup and calibration play such a significant role in a hobby (regardless of vendor), can be consistently lacking. Guess that's why we have forums.
