Why don't matched speakers sound the same?
Schwingding
Schwingding Posts: 363
That is the theory, right? A CSi5, for example, is the "matched" speaker for the RTi series. The SC80 in ceiling is supposedly the "matched" speaker for the RTi series.
Pink noise test tones sound VERY different in these speakers as compared to the RTi10 and RTi8 speaker sets I have. The 10s and 8s, they sound identical. The 5 - while a superb speaker, sounds quite different when producing the same pink noise tones, and the SC80 isn't even in the same ballpark.
Why am I trying to buy matched speakers if they don't match? Is my thinking wrong on this? Shouldn't these speakers produce material in the same "timbre" if they're "matched"?
HT/music rig
Panasonic PX60U 50" plasma
Yamaha 5990 AVR
Onix SP3 tube amp
bunch of Outlaw 2200 monoblocks
DUAL SVS PB12+/2 subs :eek:
Denon 3910 DVD/SACD/DVD-A
DirecTV HR10-250 DVR
Onix Strata Mini mains
Mirage OM10 surrounds
Polk CSi5 center
Polk SC80 rear surrounds
Samsung BDP1000 blu-ray player
Bedroom rig
Jolida SJ302a tube amp
Denon 2910 universal player
Onix Ref 1 monitors
Velodyne minivee
Post edited by Schwingding on
  • danger boy
    danger boy Posts: 15,722
    edited November 2006
    the only thing i can think of.. and I have no research to back this up..
    but I think that center channel speakers are tuned differently.. because for the most part carry mostly dialog and not much surround sounds. I could be wrong. but if they use the same drivers, and tweeters... they should be timbre matched to your mains.
    PolkFest 2012, who's going>?
  • PolkThug
    PolkThug Posts: 7,532
    The Csi5 has a different style crossover, but I bet if you ran a freq sweep, the high-end would match the Rti8's.
  • danger boy
    in a home theater set up.. say a 5.1 system.. are all speakers just mono? a speaker is only stereo when it has a left and right speaker, correct?
    so in say my home theater.. each speaker is receiving a mono signal.. but once combined with all 5.1 speakers it becomes surround sound?
    sorry for the derail Schwingding.
  • PolkThug
    Yes, but they are distinct.
  • sucks2beme
    sucks2beme Posts: 5,685
    Putting a speaker in the wall or ceiling has to sound different than a regular speaker. For one, the enclosure is not wood. Two, there is no back wall reflection on an in-wall speaker. The wall/ceiling IS the enclosure, and maybe only a so so one at that.
  • Schwingding
    Of course I understand that, but those speakers are designed to be matched. So how does one design or determine what is a "matched" speaker. If they test them in free air, what good is that, since they will never be mounted as such.
    How about for the center channel? What exactly determines a "matched" speaker is what I'm really getting at.
    HT/music rig
    Yamaha 5990 AVR
    Onix SP3 tube amp
    Polk CSi5 center
    Bedroom rig
    Onix Ref 1 monitors
    Velodyne minivee
  • PolkThug
    If you wanted to be "100% matched" you would need identical drivers/x-overs/enclosures in each location.
  • Schwingding
    Don't laugh too hard - I have been considering just that - 5 RTi10s.
    HT/music rig
    Yamaha 5990 AVR
    Onix SP3 tube amp
    Polk CSi5 center
    Bedroom rig
    Onix Ref 1 monitors
    Velodyne minivee
  • sucks2beme
    I've got a Paradigm cc370 running with RTI10's. It gets the job done well.
    Is there a problem with how your system performs? Or did you just notice it
    while doing channel levels? As someone already stated, the center is built differently than the regular speakers because it does a different job.
    I always felt that wall mount speakers weren't as good as regular speakers.
    It comes down to WAF, as always. If she ain't happy, nobody's gonna be happy.
  • Drumingman
    Drumingman Posts: 348
    While center channel speakers have their place, I don't use them.
    Since i use my system for TV and music I use 4 R50's across the front.
    I get a big sound stage and timbre matching is not a problem.
    I like a big coherent sound and small center speakers have never done it for me.
    But to each his own.
  • NCNog
    NCNog Posts: 11
    edited December 2006
    The pink test tones out of my Monitor 30's sound louder and brighter than the same tone out of my CS1. They should be "matched". Is this normal?
  • Emlyn
    Emlyn Posts: 4,729
    I wouldn't be concerned about how pink noise test tones sound from the speakers. Make sure the speakers are balanced to the same sound pressure level using the test tones. How do the speakers sound together when playing active movie and music material? As long as you are satisfied with how the speakers sound, you have nothing to be concerned about. I found the CSi3 and CSi5 to sound quite a bit different when compared side by side, and chose the CSi5 because it seemed to be a closer, bigger sounding, match to the RTi12's I had. Both would have been acceptable though. There's no such thing as a perfect match with a center speaker. Even with identical speakers, room intereactions may make the same speaker sound slightly different if it's used in the center of the system.
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    Have you had the CS1 longer than the 30's? I believe the Monitor series is extremely "bright" right out of the box.
  • jakelm
    jakelm Posts: 4,081
    Speaker level is probably the #1 reason why some people think their speakers dont have a closer match. IMO no 2 speakers sound 100% alike. And with different SPL's they will seem even farther apart.
    Jake
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
