Hdcd
edited December 2006 in Electronics
I may be a little confused here.... DKG999 brought over a CD that was an HDCD yesterday. In playing it in my DVD player, which is connected via tos-link, my H/K flashed "HDCD" on the screen when it began to play.
Is HDCD a different format, a more dense bit stream?...what exactly is it? I have a rather cheapo DVD player and am certain it wouldnt' "decode" HDCD, but I am not really using the DAC in the DVD player. Does the player just send a straight bitstream of whatever it reads to the HK and then the DAC in the HK recognizes it as an HDCD?
Again, a clarification of what exactly and HDCD is would probably help my understanding, but I would also be interested in any personal thoughts on HDCD.....
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
Post edited by Lowell_M on
Welcome!
    edited November 2006
    What a search found:
    "HDCD (High Definition Compatible Digital) is a digital encoding and decoding process for compact disc and DVD audio recording. The HDCD process manages to encode 20 bits of audio information into a conventional CD 16-bit channel, yielding a greater dynamic range and a more true-to-life sound when decoded. HDCD was developed by Keith Johnson and Pflash Pflaumer between 1986 and 1991, and made publicly available in 1995. Johnson and Pflaumer went on to found Pacific Microsonics, which was later acquired by Microsoft. Since 1995, more than 5,000 HDCD recordings have been released and more than 175 of those have been nominated for GRAMMY awards. An article in Wired Magazine hailed HDCD technology as "the greatest single advance in digital reproduction to date."
    Audio chip manufacturers including Motorola, Sanyo, and Zoran have developed HDCD chips for audio products, such as CD and DVD players and receivers. HDCD-encoded media will play on machines that don't have the chip, and HDCD-equipped machines can play traditionally recorded media. Because the decoder chips include a high-precision digital filter, HDCD-equipped players will improve audio quality for even traditionally recorded CDs and DVDs. Conversely, because of the recording process, HDCD-encoded media will also sound better than traditionally CDs and DVDs on players that don't have the HDCD chip. Nevertheless, the best audio quality is yielded by HDCD-encoded media on an HDCD-equipped player."
    Audio chip manufacturers including Motorola, Sanyo, and Zoran have developed HDCD chips for audio products, such as CD and DVD players and receivers. HDCD-encoded media will play on machines that don't have the chip, and HDCD-equipped machines can play traditionally recorded media. Because the decoder chips include a high-precision digital filter, HDCD-equipped players will improve audio quality for even traditionally recorded CDs and DVDs."
    I have two, tube output CDPs with HDCD capability and HDCD media is very noticably (as noted above) of "a greater dynamic range and a more true-to-life sound."
    all an HDCD is a slightly higher resolution Redbook CD. it can be played in ANY cd player. but if the player can decode HDCD is will give you an extra 4 bits of info. LIke stated above.. all Redbook CD's are mastered at 16bits, HDCD's are mastered at 20 bits. DVD-audio at 24bits. so the more bits, the higher resoultion and should be much better sounding.
    no special CD player is needed to play HDCD's. and they've been around for years.. just that often times CD's aren't labeled at HDCD's anymore.
    PolkFest 2012, who's going>?
    The Guys at Spectral developed it back in the early to mid 90's.Interestingly I find a lot of Country music artists CD's are done with HDCD.
    Testing
    Testing
    Testing
    A question: If compatibility with regular CD players is not affected, why not encode all new CDs in HDCD, especially if higher fidelity is acheived than a standard 16-bit CD?
    Does it use a different media, or is it simply a different recorder that manages to squeeze more data onto a standard cd?
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
    Good question, I wish "they" would, I have yet to hear a poorly recorded HDCD.
    Ok....This is starting to make sense to me, but.... Does this mean that since my H/K flashes "HDCD" on the front when an HDCD is put in that the DAC is actually getting all 20 bits of information from my DVD player and therefore playing the full HDCD sound?
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Eveidently the H/K will decode HDCD when fed an optical signal from the source and you should be getting the higher resolution playback.
    HDCD is now owned by Microsoft.
    Here's a link to a thread I started a while back. It has two links in the thread that provide info on HDCD titles, which I found useful since many HDCD's are not even labled as such. I initially discovered this when playing a John Lee Hooker disk which has no markings for HDCD anywhere on the disk or case. Why bother to make a higher quality product and not market it as such? I would definitely be more likely to grab an HDCD over standard Redbook when given the choice.
    UNIVERA
    Historic Charleston SC
    2 Channel:
    SDA-SRS's RDO tweets
    Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
    Anthem Pre 2L w/E.harmonix platinum matched 6H23's
    CDP- NAD C 542
    HT setup:
    AVR: NAD T 773
    Rears: Polk LC80i
    DVD: Toshiba 3109 dual tray
    Subs: Velodyne and M&K
    T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
    Conditioner: Panamax M5100EX
    Master Bedroom Sony 40KDL-XBR3
    "I love it when a plan comes together." Hannibal Smith, The A-Team
    Microsoft used to have a database with a partial list of HDCD-encoded CDs. However, MS has decided to delete the site. Over at head-fi.org, there's a ongoing thread that tries to identify all unmarked HDCD-encoded CDs (it was started before MS deleted its own HDCD site) and it should also have a link to a Swedish website that tries to replace the MS site.
    I wonder how HDCD compares to upsampled 24/192? Has anybody done a comparision?
    Ok. I'm confused and half frustrated....
    I bought the Jewell Christmas CD tonight, which has the HDCD emblem on the back. When I played the only other HDCD I have seen, my AVR-635 flashed "HDCD" on the front to indicate an HDCD was being played and decoded (which I verified in the HK owners manual). Now, while this CD sounds fantastic, the receiver is not indicating that it is an HDCD.
    ???????????? Anybody have an H/K and know what I am talking about?
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    What is upsampled 24/192? Right now I was goign down the road of finding some nice HDCD recordings. I did see a CD by "The Band" tonight that was "mastered in 24 bit". Is this what you are referring to?
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
Welcome!
Welcome!
