To bypass or not to bypass?
Coblio
Coblio Posts: 13
edited November 2006 in DIY, Mods & Tweaks
While I don't qualify as a speaker-tweaking expert, I have designed and built two studio monitor systems from scratch I've been quite pleased with; I gave one pair to a musician friend for his home studio and he and his fellow geetar pickers were impressed enough to request two more pairs. My main interest, however, is rebuilding and upgrading older commercial systems with modernized drivers and crossovers--vintage Klipsch, Polk, Celestion and Advents to date.
There's a ton of data out there regarding the benefits of bypassing large-value crossover caps (I mostly use Solens, though I plan to go with Black Gate bi-polar 'lytics in my next project) with small-value audiophiliac metallized film and film/foil caps. There are certainly many manufacturers willing to sell high-priced caps specifically for this purpose, and reams of published data that demonstrates their superior performance, at least on paper.
Being a trusting and gullible type by nature, for my last two projects--rebuilding the crossovers for my Klipsch KG4's and Polk RTA11-TL's--I bought a supply of Audiocap PPT Theta film/foil caps to bypass, using values equivalent to 1% of the base caps. The results were a mixed bag; the Klipsch's were completely transformed (I also replaced the original phenolic dome/voice coil assemblies in the horns with Klipsch's newer and better polymer domes). I heard detail I had never heard before and at first was blown away--However I learned that the benefits were dependent on the source material. With CD's such as Alison Krauss' "Union Station Live" the Klipsch's really excelled--her soprano voice was transfixing and the speakers were smooth and comfortable throughout the range. However when I switched to other material, such as Lynard Skynnard and Stevie Ray Vaughn, the material sounded harsher and somewhat irritating. These are AAD CD's, remastered from original analog tapes, and too much high-end detail is not a good thing. I removed the bypass caps and after further listening decided to leave 'em out of the circuit. Although I miss the marvelous detail in some recordings the benefits seemed directly related to the quality of the source material.
For my tests I used CD's for comparison, although probably half my listening is on vinyl. This is probably a whole different subject, since the dynamic range and frequency response is quite different from CD.
The Polk RTA's noticeably suffered from the bypasses. This is partly due to the SL-3000 metal-dome tweeters, which I'll soon be replacing with Polk's newer silk domes, but I concluded that added detail notwithstanding the bypasses gave me a listening headache.
I've also got a pair of Celestion SL-12's, which were my primaries before I modded the Klipsch's, and in A/B listening they sound rather muddy and lacking in HF detail. With this particular speaker I think bypassing may make a positive difference.
Anyhow, I've concluded that the benefits of tweeter crossover bypassing is largely dependent on the specific speaker's characteristics and also the source material.
I wanted to see what advice you experts have to offer; I'm also interested in recommendations regarding bypassing the mid/bass crossover sections. Bypass caps are used in amplifier circuits specifically for their ability to transmit high frequency signals--cheaper caps (especially electrolytics) have lousy high frequency response. Is it worth bypassing the large woofer/midrange caps, or are the audio frequencies involved largely invisible to these drivers anyway? By adding bypasses in these positions, will I also be passing on the sonic glare I wish to avoid to the HF section of the crossover?
Thanks for any opinions y'all have to offer.
System:
B&K ST-1400 Series II power amp
Parasound P/HP-850 Pre
Adcom GCD-575 CD player
Linn Axis turntable w/Rega RB-300 Cardas-wired tonearm
Goldring 1042 MM cartridge
Klipsch KG4's, Celestion SL-12's, Polk RTA-11TL's
Post edited by Coblio on
  • schwarcw
    schwarcw Posts: 7,358
    Greetings! Thanks for your Post and experience with the by-pass caps on the various speakers. Some folks will argues that with the faster film caps vs the electrolytic, by passing is not necessary. I've used Sonicaps in my crossover upgrades and used a by-pass cap in the tweeter section of the x-over. I selected a Gen II Sonicap based on the recommendation from the manufacturer. The Gen II's were designed to be a little softer. In my experience the result was very good. No extreme harshness in any the majority of the music. It's true the source material itself could be a little on the harsh side. Then new caps may be more "revealing" of the nature of the source material. Definitely go for the silk dome tweeters, these will also help smooth out the edges. Thanks for the Post!
    Carl
  • george daniel
    george daniel Posts: 12,096
    ^^^ what he said ^^^^ :)
    F1nut Posts: 51,962
    I agree. Anyone want to buy some bypass caps cheap?
  • schwarcw
    Platinums? LOL!
    Carl
    Carl
    F1nut Posts: 51,962
    Yep.
  • phoneisbusy
    phoneisbusy Posts: 867
    What values do ya gots?
    regards
    Dave
    Time is the best teacher. Unfortunately it kills all its students.
  • Systems
    Systems Posts: 14,872
    I don't see any benefit in bypassing good poly's like the Solens, but I would bypass any electrolytics that are in series with any driver.
    Testing
    Testing
    Testing
