How Do I Get The Best Sound?
EFW
EFW Posts: 28
:confused: I have an Onkyo TX-SR703 pushing my Polk's which consist of:
2-Polk Monitor 70's (Front)
2-Polk Monitor 40's (Rear)
1-Polk CS2 (Center)
1-Polk PSW 12 (Power Sub)
I curently have the two front speakers running through the Sub, with the center and rear coming off of the AVR. Is this the best way to get the best sound? Or should everything come off of the AVR? Also I am consicering Bi-Wiring the Monitor 70's (Front). Is this a good move? If so how do I go about doing it? Any information or links to information on the above subjects would be helpful thanks...............Polk Rookie:cool:
AVR...........Onkyo TX-SR703
TV.............Mitsubishi WD-62627:D
HD DVD.......Toshiba HD-XA2:cool:
Power.........Monster HTS 1600
Mains.........Monitor 70's
Center........CS2
Rears..........Monitor 40's
Sub............PSW12
Cables........Signal Cable
Post edited by EFW on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited November 2006
    You have a choice for wiring your fronts through the Polk sub speaker input or directly from each channel with speaker wire and use the LFE output on your receiver to the sub with the RCA cable. You must experiment with both to determine what works best for you.
    I would not worry about biwiring, just use heavy enough speaker wire (14 gauge or thicker).
  • danger boy
    danger boy Posts: 15,722
    I would wire everything off your AVR and call it good. I find that usually gives the best results.. and it is the easiest to set up too.
    PolkFest 2012, who's going>?
  • TheReaper
    TheReaper Posts: 636
    If you connect using the lfe output from your receiver to the subwoofer. There are some functions in your receiver you can play with: eq, distance, bass boost
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
