What's the deal with electrostatic speakers?
lsi9dwglsi9dwg Posts: 4
edited November 2002 in Speakers
How about a healthy discussion about electrostatic speakers?
I'm guessing that this question will cause riot from all you Polkologists and the like. :supermad:
So........what does everyone think? Do they have merit?
What is good or bad about them? Is the technology inferior/superior to traditional speaker design,
or simply just a different way of pursuing an end?
I really don't have an opinion on the subject, I'm a happy Polk traditionalist. I just want to know what the collective
knowledge base out there thinks. :)
Post edited by lsi9dwg on
  • TroyDTroyD Posts: 12,321
    It depends on what you are looking for.
    IMO, they have a LOT going for them. They don't have cabinet resonance issues because there is no cabinet. The are usually incredibly transparent, very detailed. The stereo image is usually impeccable.
    Some of the drawbacks are that they tend to be very placement sensitive for one. The also can be very demanding on an amp, so of the nominal ohm loads aren't much more than a short circuit. They are expensive, and if you want deep bass, even more expensive......
    I tend to think of them as a purist speaker, if you are looking for transparency and detail without being on a budget, electrostats are probably the way to go.
    I like my Polks, but give me a pair of the old Dayton Wrights or KLH-9's and NOW we are talking...
    BDT
  • organorgan Posts: 5,022
    Troy just mentioned everything I have heard and read about electrostats. Accurate, transparent, very detailed, lack some bass, etc.
    I think mantis have installed electrostats in the past. Maybe he could enlighten us with his electrostats experience.
    It seems like they have their own followers, much like Klipsch. People who don't like them complain about their lack of dynamics. But electrostats lovers say they're the most accurate and detailed. It's like Klipsch haters saying Klipsch are too bright and Klipsch owners saying horns are more accurate and detailed.
    Maurice
  • joe logstonjoe logston Posts: 882
    my self i like dynamic speakers better than electrostats there is some reason that the e-s dont blend with bass, they are missing something, they have great highs & no lows. wend they add a sub it seems they still dont work right.
    . rt-7 mains
    rt-20p surounds
    cs-400i front center
    cs-350 ls rear center
    2 energy take 5, efects
    2- psw-650 , subs
    1- 15" audiosource sub
    lets all go to the next ces.
  • phuzphuz Posts: 2,413
    Something seems fishy about this thread, but I can't quite put my finger on it.
Howdy, Stranger!
