Help 4ohm or 8ohm
PaPa Jim
PaPa Jim Posts: 4
Knowing that 4ohm is better than 8 ohm for performance, can my system handle a 4ohm set up?:rolleyes: :rolleyes:
Sony STR-DG1000
Rti-6 Mains
Csi5 center
Fxi5 rear
Psw 505
Post edited by PaPa Jim on
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2006
    It might but not very well, and 4 ohm is not by design necessarily better than 8 ohm. There are just alot of nice 4 ohm speakers. There are also many high quality audiophile grade speakers with 8 ohm resistance.
    RT1
  • scottvamp
    scottvamp Posts: 3,277
    edited October 2006
    It depends what your speakers ohm spec's are. That is what you operate at. Most home speakers are 8 or 6. Car speakers are 4. Your amp also has to be rated to operate at 4 ohms.
    How do you plan to run your system at 4 ohms?????
  • read-alot
    read-alot Posts: 812
    edited October 2006
    He is probably looking at these.http://www.polkaudio.com/homeaudio/specs/lsi15/
    Which give 4 ohm as the load.
    I don't see in the Sony spec sheet where that unit can carry a 4 ohm load.
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • PaPa Jim
    PaPa Jim Posts: 4
    edited October 2006
    Polk specs say 8ohm nominal on all speakers.
    The amp manual says it will operate as follows
    At 8 ohms and also at 4 ohms
    Front 120w + 120w
    Center 120w
    Surround 120w + 120w
    Surround Back 120w + 120w
  • PaPa Jim
    PaPa Jim Posts: 4
    edited October 2006
    Fronts (RTi6)
    Overall Frequency Response 40Hz-27kHz
    Lower -3dB Limit 50Hz
    Upper -3dB Limit 26kHz
    Nominal Impedance 8 ohms
    Recommended Amplifier Power 20-125 w/channel
    Efficiency 89 dB
    Crossover 2.8kHz, 12dB/octave high and low pass
    Inputs Dual (bi-amp) gold plated 5-way binding posts
    Surrounds (FXi5)
    Overall Frequency Response 45Hz-27kHz
    Lower -3dB Limit 55Hz
    Efficiency 89 dB
    Crossover 2nd order LP/ HP complement 2.3kHz
    Inputs Gold plated 5-way binding posts
    Center (CSi5)
    Recommended Amplifier Power 20-200 w/channel
    Efficiency 90 dB
    The Amp also has 4 or 8 ohms option in the setup screen
  • scottvamp
    edited October 2006
    If you run 8 ohm speakers at 4 than you increase the chance of burning up your speakers voice coils. Your reciever will also run much hotter.
    In your case, with your equipment, 8ohms is what you need to stay at.
  • PaPa Jim
    PaPa Jim Posts: 4
    edited October 2006
    :eek: Thanks :eek:
    good thing I asked first
  • scottvamp
    edited October 2006
    PaPa Jim wrote:
    :eek: Thanks :eek:
    Welcome to the forum!!!!!!!
  • McLoki
    McLoki Posts: 5,231
    edited October 2006
    I think he means what happens if he sets the switch on his AVR to 4 ohms when running his 8 ohm speakers.
    If that is the case - all the 4 ohm switch does is throttle the amount of current that your AVR can produce (so it won't go into protect mode as easily with a 4 ohm load). It will work with the 4 ohm setting, but doing so may limit the power, current and dynamics of the amp when it really does not need to.
    It shouldn't break anything though.
    Michael
    (and yes - welcome to club polk)
  • Lowell_M
    Lowell_M Posts: 1,660
    edited October 2006
    I accidentally ran my POS JVC receiver switched to 4 ohm for over a year and didn't notice any difference.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
