Help 4ohm or 8ohm
PaPa Jim
Knowing that 4ohm is better than 8 ohm for performance, can my system handle a 4ohm set up?:rolleyes: :rolleyes:
Sony STR-DG1000
Rti-6 Mains
Csi5 center
Fxi5 rear
Psw 505
Sony STR-DG1000
Rti-6 Mains
Csi5 center
Fxi5 rear
Psw 505
Post edited by PaPa Jim on
It might but not very well, and 4 ohm is not by design necessarily better than 8 ohm. There are just alot of nice 4 ohm speakers. There are also many high quality audiophile grade speakers with 8 ohm resistance.
RT1 -
It depends what your speakers ohm spec's are. That is what you operate at. Most home speakers are 8 or 6. Car speakers are 4. Your amp also has to be rated to operate at 4 ohms.
How do you plan to run your system at 4 ohms????? -
He is probably looking at these.http://www.polkaudio.com/homeaudio/specs/lsi15/
Which give 4 ohm as the load.
I don't see in the Sony spec sheet where that unit can carry a 4 ohm load.polkaudio SRS (rdo194 x 8)
Dodd ELP (separate power supply)
JC 1 blocks ( strapped )
Rega Apollo
MIT (speaker cables) Outlaw (ICs)
polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
Polk specs say 8ohm nominal on all speakers.
The amp manual says it will operate as follows
At 8 ohms and also at 4 ohms
Front 120w + 120w
Center 120w
Surround 120w + 120w
Surround Back 120w + 120w -
Fronts (RTi6)
Overall Frequency Response 40Hz-27kHz
Lower -3dB Limit 50Hz
Upper -3dB Limit 26kHz
Nominal Impedance 8 ohms
Recommended Amplifier Power 20-125 w/channel
Efficiency 89 dB
Crossover 2.8kHz, 12dB/octave high and low pass
Inputs Dual (bi-amp) gold plated 5-way binding posts
Surrounds (FXi5)
Overall Frequency Response 45Hz-27kHz
Lower -3dB Limit 55Hz
Efficiency 89 dB
Crossover 2nd order LP/ HP complement 2.3kHz
Inputs Gold plated 5-way binding posts
Center (CSi5)
Recommended Amplifier Power 20-200 w/channel
Efficiency 90 dB
The Amp also has 4 or 8 ohms option in the setup screen -
If you run 8 ohm speakers at 4 than you increase the chance of burning up your speakers voice coils. Your reciever will also run much hotter.
In your case, with your equipment, 8ohms is what you need to stay at. -
:eek: Thanks :eek:
good thing I asked first -
Welcome to the forum!!!!!!!PaPa Jim wrote::eek: Thanks :eek:
I think he means what happens if he sets the switch on his AVR to 4 ohms when running his 8 ohm speakers.scottvamp wrote:If you run 8 ohm speakers at 4 than you increase the chance of burning up your speakers voice coils. Your reciever will also run much hotter.
If that is the case - all the 4 ohm switch does is throttle the amount of current that your AVR can produce (so it won't go into protect mode as easily with a 4 ohm load). It will work with the 4 ohm setting, but doing so may limit the power, current and dynamics of the amp when it really does not need to.
It shouldn't break anything though.
Michael
(and yes - welcome to club polk)Mains.............Polk LSi15 (Cherry)
I accidentally ran my POS JVC receiver switched to 4 ohm for over a year and didn't notice any difference.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
