Spikes for my LSi15's
Hi! I finally got around to taking the rubber feet off my speakers and want to know if any of you who also have the same speakers have put different spikes on them. I did a search here and found a couple of different places to buy them from which I will put below. Im not sure which ones to get so any suggestions would be appreciated. As always, thanks so much for your help.
Cindy
http://www.myesound.com/products.html
http://www.partsexpress.com
Cindy
Post edited by cindy100 on
I'd recommend the Myesound spikes. Good quality, reasonable price.Carl
Mye Sound spikes are works of art. Be sure to tell them you need 10-24 threads.Political Correctness'.........defined
