Why is Matrix Reloaded DVD so Quiet
sabotg
I recently bought a new Pioneer Elite VSX72TXV Receiver to replace a HTIB Onkyo receiver. I'm also slowly swapping out the original 6.1 setup with POLK RTI speakers (L/R RTI-10) and I've swapped out the sub with a Velodyne DLSR-5000. The swap to the Pioneer was amazing. I can hear every little detail of sound in movies and overall the experience is way better. Here's my problem. Most of the movies I play I set the receiver to a volume level of -20 which is where I'm comfortable with most movies. For example when watching Saving Private Ryan -20 is pretty loud and I wouldn't want to push it any louder. But when I watch Matrix Reloaded it's actually pretty quiet at this volume level and it almost seems like I can't get it loud enough. Both movies are playing Dolby Digital (I play DTS whenever I can)
Has anyone experienced this? I realize that both films soundtracks are mixed differently but something doesn't seem right.
Post edited by sabotg on
Your Fine.........Eliab/Dave Abrams calibrated Panny
Yamaha,Denon,Toshiba "in the rack"
Polks all around
SVS on the floor -
Ummmmm, that would be spelled: You're Fine.........
I've had that with my setup too, I'm thinking it's just a matter of different sound volume "saturation" levels -- some DVDs are maxed and some are quieter.
Were they as different with your old setup? -
Very good petrym....I'm usually a fanatic about proper spelling and syntax..A MAJOR ERROR ON MY PART....but I was in a hurry...
I noticed the same thing on my system,,,some DVD's just play louder than others.."Matrix Revolutions" is even worse...If you ever think your system sounds "too quiet" just spool up "Underworld" or "Blade II"Eliab/Dave Abrams calibrated Panny
Polks all around
SVS on the floor -
Different movies have different volume levels sometimes. It's all good.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Thanks for all the responses. I didn't notice this as much with the old HTIB (onkyo S760) receiver. I'm glad that it's not something on my end and that other people have had this experience. I have blade 2 so I'll give that a whirl.:)
My Styx concert DVD has to be seriously cranked to get any volume out of it...like 1 o'clockish, almost a full 1/4 turn from normal.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
steveinaz wrote:My Styx concert DVD has to be seriously cranked to get any volume out of it...like 1 o'clockish, almost a full 1/4 turn from normal.
I understand that some (all?) concert DVDs would be at different sound levels according to where the mics were placed to record the show. However I was under the impression that all movies were attempted to be recorded at a certain "reference level". I thought that was one of the reasons that you can actually calibrate your system.
I can understand that there will be those poor recordings. So is Matrix Reloaded one of those poor recordings?
Sorry if this is a silly question.Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
http://www.austin360.com/music/content/music/stories/xl/2006/09/28cover.html
http://web.archive.org/web/20031208110318/http://www.prorec.com/prorec/articles.nsf/articles/8A133F52D0FD71AB86256C2E005DAF1C
Reading these articles was pretty interesting & I have noticed that with alot of CD's I have. I wonder if the same goes for the movie industry & how they master movie soundtracks. -
Holydoc check to be sure you don't have something like Midnight mode enabled on your receiver... my Outlaw pre amp doesn't have a red light to let me know it's enabled like my Marantz used to .. so it's caught me several times recently.. where I have to raise the volume to get a decent level.PolkFest 2012, who's going>?
Holydoc wrote:I understand that some (all?) concert DVDs would be at different sound levels according to where the mics were placed to record the show. However I was under the impression that all movies were attempted to be recorded at a certain "reference level". I thought that was one of the reasons that you can actually calibrate your system.
It really doesn't have anything to do with the recording/design techniques it is how the film is mixed/mastered on the stage. You have to realize that a movie like the Matrix starts off with over 3,000 element tracks and is then downmixed to pre-dubs, stems, etc. When played back in AC3 the entire movie is run through a black box from Dolby Labs which determines the Dialog Normalization which is judged by the level of the dialog throughout the film. (the average level) There are different levels where there is a flag to tell the decoder how to handle the volume attenuation. It is also used all over broadcasts as well to keep the volume between the show you are watching and the commercials you watch to make sure that everything is at the same level. You will sometimes notice that some local commercials can be crazy loud and that is because there is no dialnorm flag associated with it.
Whenever I master a 5.1 film mix I try to have the levels as high as possible while retaining the dynamic range and making sure the least amount of compression occurs. If you ever encode something to AC3 it will ask you to select the dialnorm setting and the only real way to properly calibrate it is if you run it through one of Dolby's boxes.
You can read more about it here.
http://www.minnetonkaaudio.com/pdfs/Dolby%20Digital%20Guidelines.pdf// Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
// Polk Audio FXi A6 // SVS PB12-NSD Subwoofer // Logitech Harmony Ultimate // Pro-Ject Debut III //
// Oppo BDP-103 // Microsoft Xbox One Day One Edition // Sony Playstation 4 1TB SSHD // Nintendo Wii U //
Photo Gallery
Movie and Game Collection
