Towers with built-in subs... wiring?
dane_peterson
I was over at Best Buy Magnolia today, checking out the Martin Logans. (mmm mmm mmm, sound is so crisp) I stopped to look at the Definitive towers, and it got me to thinking... how do you wire them?
Obviously you do your speaker cable out, but then there's the line input. Do you do a split subwoofer line out? And what if the center channel also has a powered sub... what do you do in that circumstance?
I'm sure it makes perfect sense, I'm just stumped by it. I did a search and didn't turn up with any applicable info. Thanks for the help guys!
Post edited by dane_peterson on
With speakers like my Polk RT1000p's, you can also use the "line level" method, which is as simple a using or making jumpers.
Sorry for my negligence, but can you elaborate?
Thier are two sets of binding post. One for the speakers and one for the subwoofer. You can use the line in or just use a jumpers to get the signal to the sub. With the sub cable method you just daisy chain the cables. I did it with 4 subs and it worked fine.
Gotcha, makes sense now.
So what about the line in? At Best Buy, they have one set of wires connected, as well as a line in. Does the line in provide full audio support as well, or only for the sub? -
I have used a special split rca for mine before. It takes the line out and split it three ways for use with three subs. You can also (on my speakers) send the lfe signal to a speaker and then out of that speaker into the next one. Each of my speakers has an LFE input and an output.
Now I have an SVS sub so all my tower and center subs run off line level.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
I have rt2000i"s and was wondering about this.If I put the jumper back on and only run the one set of wires to the speaker does this bypass the biult in amp on the subs?
The amp works either way but do not use the jumpers with the lfe input.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
What I was thinking is run the mains without subs and try an svs.Could you run the mains on small and use the LFE for svs.
If you wire the mains with speaker wire and the jumper; the sub in the speaker will produce the sound meant for that speaker.
Then run the lfe to the svs.
So the answer is yes.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Thanks Skynut,
All the talk here about the SVS's has got me thinking my subs sound boomy darn this bunch;)
I wish I could find someone close to compare mine with the SVS.
My next step is 2 Outlaw m2200's for my mains for music and then the sub. -
Use the line level input. Unless ur LFE output on ur receiver has an adjustable low freq, it may not be crossed over at the desireable hertz and might give u less then desirable sound. I would use the LFE strickly for a sub only. I have the RT1000I's but my LFE output was at a fixed freq and I lost a lot of the BOOM from them when I did go the other route.Yamaha HTR-5490, Polk RT1000I, cs4000i, CS175 and R10 .... and a soon to be SVS 20-39 PCI
Okay guys, got the speakers, now this is what I've determined:
I can run the Left and Right preouts from the receiver to the LFE, and it gives it a little more bass. Or I can run the SW preout, and it gives it a LOT of bass. Which would be the more preferred method... run the L/R preouts to LFE in addition to a subwoofer? Or run the SW preout and split the output to both channels? Will I lose any audio if I run sw outs to the towers and not the L/Rs?
Hopefully this makes sense... I'm nearly confusing myself. -
On my LSi25s, I run the sub out to the LFE inputs on both towers via a Y interconnect piece. I have removed the jumpers on the speakers so that the top acts as the true fronts and the bottom acts as two subs on a single sub output. For bass management I send anything below the front cutoffs to the subs along with the LFE channel. Works great for me.
RuinDenon AVR4806CI
Denon DVD3930CI
Panamax 5500-EX
Polk LSi25 mains/subs
Polk LSiC center
Polk LSi9 Surrounds on Custom Skylan stands
Mitsubishi WD-65831
Audio Art IC-1 Interconnects
Audio Art SC-5 Speaker Wire -
Yeah.
I discovered these towers only have a hi in, no low except for the LFE. So maybe I'll do it that way. Then how bout for the center? It too has a built-in sub... should I just run the center preout to that one? I can't imagine splitting the sub audio 3 ways... -
I wouldn't split out the sub portion of the center myself. You might set its crossover a bit higher though since you probably don't want the extreme low end also coming from your center. At some point you are going to run into issues having the same low frequency coming from too many seperate sources.
RuinDenon AVR4806CI
Denon DVD3930CI
Panamax 5500-EX
Polk LSiC center
Mitsubishi WD-65831
That's why I'm thinking I just run the center preout instead of another split sub. Does that make the most sense?
It does to me anyway.
RDenon AVR4806CI
Denon DVD3930CI
Panamax 5500-EX
Polk LSiC center
Mitsubishi WD-65831
