Need Help To Fit In My Subs
Systems
I HAVE A 91 GMC SERRIA EXT CAB AND I HAD A BOX FOR 2 10 INCH SUBS BUT IT GOT STOLEN NOW I HAVE 2 12 INCH SUBS AND I NEED A WEBSITE WHERE I CAN BUY A BOX OR DIMENSIONS SO I CAN ATTEMPT TO BUILD ONE
Testing
Testing
Testing
Testing
Testing
dude check out www.sounddomain.com as well -- i'm nto sure on the sierra / silverado's but i do know that they have probably 50 - 100 different custom pre-made boxes for extended cab trucks. might take a while to search through but some of their stuff by RT is really respectable and hte prices aren't bad either -- just make sure whatever u do that you don't buy an abs plastic box (mtx thunderform or Qlogic) --- they're HORRIBLE and the walls flex with subs that take over 150 rms.
good luck.
The Artist formerly known as PoweredByDodge
