amp outputs
calarco68
What do you use the RCA line level out of your amps for? daisy chain them for fun? thanks, chris
Post edited by calarco68 on
Edit - car amps, not home - I will go back to my corner now.
if you have only 1 preout on your deck, you can just run the output to another amp, etc
-CodyMusic is like candy, you have to get rid of the rappers to enjoy it
