Liberty Basic Programming Language...HELP!
audiobliss
audiobliss Posts: 12,518
edited April 2024 in Clubhouse Archives
Ok, you're right. I shouldn't have put off doing this lab for my computer class (Introduction to Programming and Logic) 'til the night before...but, I'm me...and so I did. And I'm running across a few problems. Before I go to the length to explain my situation, is anyone familiar with the language Liberty Basic?
Someone say yes...pleaaaaaaaase!
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited October 2006
    Audiobliss, my opinion is that basic is pretty much basic.
    Sure, Visual Basic, et al, all have their own bells and whistles but if someone is familiar with Visual Basic, they can probably help you fudge it into Liberty Basic.
    A good site with a pretty active Forum section is:
    http://libertybasic.conforums.com/
    Post your problems there, and you should get some quick help.
    TUCOWS has some downloadable software that might help (not sure where you're getting stuck at). It's shareware ($20 to buy :rolleyes: ):
    http://www.tucows.com/preview/400801
    ....next time, don't be such a procastinator. :)
  • audiobliss
    edited October 2006
    Thank you very much! I appreciate your input!
    I was getting stuck with a DO WHILE loop, but I think my problem was actually not using quotes around a string variable. I have that figured out, but now I'm trying to figure out how to format my output to make it more presentable.
    Anyhoo, thanks for the links very much, and I'll be sure to get a jump start on the next lab assignment! :)
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited October 2006
    Well, I finally figured it out. I've been writing this program now for probably the better part of three hours; but now it works! AND, I've had no help. Sure, I posted on the forum mrbigbluelight linked to, but they took just a few minutes too long to respond...either that or I was too fast ;)
    So, anyhoo, now that I figured it out...and stayed up 'til 3am doing so...you better believe I'm going to post it here and brag about it!!!
    First off, the program's purpose. The user is prompted to enter a license plate number, customer name, cost of repair, and a repair code. Then the computer figures the total price based on the cost of repair and differents for the different repair codes. Then it displays the results. It's setup to continue this in a loop unti the 'dummy record' with license plate 'zzz000' or 'zzz 000' is entered, at which point the program is finished.
    So, here's the code:
    [start]
    GOSUB [houseKeeping]
    GOSUB [mainLoop]
    GOSUB [finishUp]
    END
    [houseKeeping]
    'declare variables
    'open files
    'print headings
    GOSUB [getInput]
    RETURN
    [getInput]
    INPUT "Enter the customer's license plate number:==> " ; licPlate$
    INPUT "Enter the customer's name:==================> " ; custName$
    INPUT "Enter the cost of repair:===================>$" ; repCost
    INPUT "Enter the repair code:======================> " ; repCode
    RETURN
    [mainLoop]
    DO WHILE licPlate$ <> "zzz000" and licPlate$ <> "zzz 000"
    GOSUB [processInput]
    GOSUB [printOutput]
    LOOP
    RETURN
    [processInput]
    SELECT CASE repCode
    CASE 1
    repCodeDef$ = "MAINTENENCE"
    payAmt = repCost
    CASE 2
    repCodeDef$ = "MINOR REPAIR"
    labor = 25
    payAmt = repCost + labor
    CASE 3
    repCodeDef$ = "MAJOR REPAIR"
    labor = .30 * repCost
    CASE 4
    repCodeDef$ = "DETAIL WORK"
    labor = .40 * repCost
    CASE ELSE
    repCodeDef$ = "INVALID DATA"
    END SELECT
    RETURN
    [printOutput]
    CLS
    IF repCodeDef$ = "INVALID DATA" THEN
    PRINT "Customer's license plate number:=> " ; licPlate$
    PRINT "Customer Name:===================> " ; custName$
    PRINT "Cost of repair:==================>$" ; USING("####.##",repCost)
    PRINT
    PRINT " INVALID CODE"
    ELSE
    PRINT "Labor:===========================>$" ; USING("####.##",labor)
    PRINT "Amount of Payment:===============>$" ; USING("####.##",payAmt)
    PRINT "Type of repair completed:========> " ; repCodeDef$
    END IF
    GOSUB [pause]
    RETURN
    [pause]
    PRINT
    PRINT
    INPUT " Press Enter to enter next record" ; temp$
    CLS
    GOSUB [getInput]
    RETURN
    [finishUp]
    'close files
    PRINT
    PRINT " END OF FILE REACHED"
    RETURN
    Oh, and if you're interested in Liberty Basic, it's a free programming language. You can quickly download the small redering program at www.libertybasic.com and plug in my program and it'll work; or you can come up with your own.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited October 2006
  • TheReaper
    TheReaper Posts: 636
    edited October 2006
