Honda Minitrail 50
opus
opus Posts: 1,252
edited April 2024 in Clubhouse Archives
I don't suppose anyone here has a minitrail laying around in their garage do they?
I know its a long shot but I need a pair of handlebars in the worst way. Well, let me rephrase that, I need a pair in a reasonable way. I can get a pair in the worst way for a $100 bucks but that ain't going to happen.:rolleyes:
It always amazes me the things that people are into on this board and I thought I would check and see.
I got my 8 year olds' minibike running and would like to replace the bent handlebars that he went through the side of the barn with.:o
kevin
The Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre) :)-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer
-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable
  • dkg999
    dkg999 Posts: 5,647
    edited October 2006
    Try eBay, lot's of used Honda motorcycle parts listed! I bought all the parts to fix a 1977 CL175 pretty reasonable. To unbend the handlebars, you can try filling them with water and freezing them, then bending them back with the ice inside the tubing. Sand will also work if you plug the ends of the tubing. The trick is to bend them back with the inside supported so they don't crimp on you. It will work for something like a minitrail or small dirt bike, I wouldn't recommend the fix for a larger dirt bike or street bike.
    DKG999
