Component vs. HDMI - which one is better?
polkatese
polkatese Posts: 6,767
edited October 2006 in Electronics
I am reading this on AVS Forum:
http://www.avsforum.com/avs-vb/showthread.php?t=716715&highlight=component+vs++hdmi
and curious if anyone here compared these two methods of connecting your Plasma/LCD/RPTV/DLP to source (including HD=DVD and/or BR)?
So, does it looks like the difference is more along: unnoticeable (no difference) to slight, if any?
I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Post edited by polkatese on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited October 2006
    I tried both for my Plasma TV I like the HDMI better so this is what I use.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • shack
    shack Posts: 11,154
    edited October 2006
    Tried both - no discernable difference on my rig (Denon 1910 and 52" Panasonic RPT). I sent the HDMI back and I now use the component cables I already had.
  • polkatese
    edited October 2006
    interesting! HDMI is overhyped? and shouldn't be the reason to upgrade, then?
  • disneyjoe7
    edited October 2006
    HDMI is digital input where Component is analog, not apples to apples.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • polkatese
    edited October 2006
    granted, but the judgement call is straight forward: can you say the picture quality is better (for you) or not? now, with HDMI 1.3 audio 5.1, the scale will tip for HDMI (the simplicity of the cablings)
  • disneyjoe7
    edited October 2006
    Picture is Better Darker blacks, sharper, overall better picture. I use a optical for audio output this goes to my AVR the HDMI goes to my TV.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • shack
    shack Posts: 11,154
    edited October 2006
    Kinda like the analog vs digital audio cables. In the end it is simply the quality of the picture that matters. As with all things AV, try it see what you like and go with it. I could tell little or no difference so I could not justify the $80 for the HDMI (in fact I probably liked the pic with the component better - but I chalked that up to familiarity). Maybe there would be more difference with a plasma vs my RPTV.
  • disneyjoe7
    edited October 2006
    It was not a difference like day and night, but an edge to HDMI for me. I did think maybe it was the difference with a plasma vs a RPTV also.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • univera
    univera Posts: 848
    edited October 2006
    PT or anyone else, can you elaborate a bit on the HDMI 1.3? I am not familiar with it. What's the difference between that and standard HDMI?
    UNIVERA
    Historic Charleston SC
    2 Channel:
    SDA-SRS's RDO tweets
    Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
    Anthem Pre 2L w/E.harmonix platinum matched 6H23's
    CDP- NAD C 542
    HT setup:
    AVR: NAD T 773
    Rears: Polk LC80i
    DVD: Toshiba 3109 dual tray
    Subs: Velodyne and M&K
    T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
    Conditioner: Panamax M5100EX
    Master Bedroom Sony 40KDL-XBR3
    "I love it when a plan comes together." Hannibal Smith, The A-Team
  • izafar
    izafar Posts: 820
    edited October 2006
    If you have fixed pixel display and your source can produce a signal that matches your display's resolution then HDMI will always be better. If you have CRT based RPTV then you wouldn’t see much difference.
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
  • polkatese
    edited October 2006
    univera, here is a good link on HDMI:
    http://hdmi.org/
    It gives you what's coming down the pipeline on HDMI 1.3 I think most gears out there are still on 1.1 spec, there are a couple ultra-high end Pre/Pro that are available with 1.3
  • unc2701
    unc2701 Posts: 3,587
    edited October 2006
    On a CRT I couldn't tell much diff HDMI vs component, except that the HDMI was really bitchy & you had to turn on the components in a certain order.
    Backburner:Krell KAV-300i
  • Sami
    Sami Posts: 4,634
    edited October 2006
    I couldn't either but I decided to keep the HDMI cables for simplicity as they only cost me $35 for a pair of 30footers. I wouldn't spend much money on HDMI cables, afterall it's a digital signal.
  • MSALLA
    MSALLA Posts: 1,602
    edited October 2006
    I used HDMI from my hd box to the TV. The picture was only slightly better, but on non-digital channels, I could only see in the square ratio. (man I just drew a blank on the number)
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • TheReaper
    TheReaper Posts: 636
    edited October 2006
    4:3 squared is 16:9
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • Sherardp
    Sherardp Posts: 8,038
    edited October 2006
    if youre using HD DVD or Blu Ray, HDMI will give you best audio/video. I asked the same question and was told this on another forum.
