FS: MIT Shotgun S3 8' Speaker Cables
SCompRacer
SCompRacer Posts: 9,121
edited September 2006 in For Sale (FS) Classifieds
MIT Shotgun S3 - Standard Speaker Cables. Not Bi-Wire. 8 Feet (2.5 meter) Long Speaker Cables - 7/10. $SOLD.
Go here for the S3 cables and here for MIT publications.
I originally got these from doro back in June. One pin is broke off one of the terminal ends. This is not a problem unless your gear has the old spring loaded speaker connections. The threads are fine on that end and hold a banana or spade securely. Boxes and cable covering in fine shape. Conservative rating is due to broken pin and being second owner.
ICONNS included. 8 5/16" spades, 4 banana, 4 nuts and two red and two black insulator sleeves. Post here is you want them, PM for finalizing sale.
Will ship double boxed.
Post edited by SCompRacer on
  • audiobliss
    audiobliss Posts: 12,518
    Not interested, but what are the nuts used for?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
    When you tighten spades on an end, sometimes they are not parallel with the binding post. Rather than twisting the thick wires to get the spade parallel with the post, run the nut on, align the spade and tighten it in the proper position. Makes it much easier to tighten the binding post nut and doesn't put a strain on the wire or your fingers.
  • amulford
    amulford Posts: 5,020
    I'll take 'em.
  • amulford
    Got them today. Excellent pack job and speedy delivery. Emailing Shack now...
    Kewl! The USPS comes through yet again. Njoy!
