FS: MIT Shotgun S3 8' Speaker Cables
SCompRacer
MIT Shotgun S3 - Standard Speaker Cables. Not Bi-Wire. 8 Feet (2.5 meter) Long Speaker Cables - 7/10. $SOLD.
Go here for the S3 cables and here for MIT publications.
I originally got these from doro back in June. One pin is broke off one of the terminal ends. This is not a problem unless your gear has the old spring loaded speaker connections. The threads are fine on that end and hold a banana or spade securely. Boxes and cable covering in fine shape. Conservative rating is due to broken pin and being second owner.
ICONNS included. 8 5/16" spades, 4 banana, 4 nuts and two red and two black insulator sleeves. Post here is you want them, PM for finalizing sale.
Will ship double boxed.
Post edited by SCompRacer on
Not interested, but what are the nuts used for?
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
When you tighten spades on an end, sometimes they are not parallel with the binding post. Rather than twisting the thick wires to get the spade parallel with the post, run the nut on, align the spade and tighten it in the proper position. Makes it much easier to tighten the binding post nut and doesn't put a strain on the wire or your fingers.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
I'll take 'em.
Got them today. Excellent pack job and speedy delivery. Emailing Shack now...
Kewl! The USPS comes through yet again. Njoy!Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
