Cursed Power cables from Signal Cable?!?
SniperREX
I bought 2 used MagicPower cord and 2 used MagicPower Digital Reference from a polkie (TonyB).
I hooked up my Philips DVD 963SA with a Digital Reference cord and it didn't turned on. It worked the day before I got the Signal Cable power cables. I tried with several other spare cables. Still no power. It was under extended warranty. So I got a new Panasonic DVD-S96 as free replacement.
I had my HK receiver AVR-7200 hooked up with a MagicPower cord for the last 5 months. Yesterday my receiver didn't turn on. No light from the power led. I tried everything. I even tried to reset the microprocessor following HK website instructions. No luck. My warranty ran out 6 months ago dang it :mad: !
Is it just a coincidence or these power cables might be responsible
TVs: Samsung S95B 65" QD-OLED (den) and LG C2 42" OLED (office)
Receiver: Denon AVR-X3700H (den) and Denon AVR-X2300W (den)
SACD and DVD-A player: Oppo BDP-83
Mains: Polk RTi8 (den) and Dali Ikon 8 (office)
Center: Polk CSi5 (den) and Polk CSi3 (office)
Surrounds: Polk FXi5 (den) and Velodyne surrounds (office)
Sub: SVS PB-2000 (den) and PCi 16-46 (office)
Post edited by SniperREX on
It's just a hunk of copper so I doubt it. What does "tried everything" mean? I presume it means you tried a generic power cord, no luck? If so, you have bigger issues than power cables, check your incoming power.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Did you check the circuit breaker? How about any fuses on/in the AVR?Political Correctness'.........defined
President of Club Polk -
I thought incoming power would cover a circuit breaker....but perhaps I didn't dumb it down enough.
Sniper - You need to establish what you CAN do, as in a given, then work forward until you replicate the failure.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Only time will tell.Political Correctness'.........defined
Amen.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Nice.
Nice.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
That comment wasn't directed @ the poster, just the potential reader.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
My bad my initial post wasn't specific enough.dorokusai wrote:It's just a hunk of copper so I doubt it. What does "tried everything" mean? I presume it means you tried a generic power cord, no luck? If so, you have bigger issues than power cables, check your incoming power.
Yep. I should have said "I tried another cable and another outlet".
I'm sorry but I don't know much about electrical and electronic stuff.
I forgot to add that my DVD player was hooked to a UPS with Automatic Voltage Regulation. So I don't think that my utility power is to blame and I didn't have any broken electronic until that DVD player in the 3 years I have been in this house.
My HK receiver was hooked to Monster Power HTS 1000 MKII PowerCenter™ with Clean Power™ Stage 2 v.2.0. I know it's not top notch. But it should have done the job, right? And all my other stuff hooked to the same powerbar is working flawlessly.
I didn't open my receiver. So I don't know if it's just a fuse. As I said I'm no electronics technician. I could ask my uncle. He is pretty good in that field.
Sub: SVS PB-2000 (den) and PCi 16-46 (office) -
Well as Doro stated the Power Cable is just that a Power Cable. Signal Power Cable sounds very nice / clean but as far as power it's just that power. It odd that your equipment as died recently but I don't think at all it's the power cable. I suspect that a fuse either on back panel or internal of you AVR is bad, having said that I feel it was a voltage spike of some kind. Perhaps Lightening?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote:Well as Doro stated the Power Cable is just that a Power Cable. Signal Power Cable sounds very nice / clean but as far as power it's just that power. It odd that your equipment as died recently but I don't think at all it's the power cable. I suspect that a fuse either on back panel or internal of you AVR is bad, having said that I feel it was a voltage spike of some kind. Perhaps Lightening?
That's what I suspected. I mean my "bad luck" started with those power cables. But it was definitely just a coincidence... I guess
There is no fuse on the back panel. I'll check this weekend with my uncle.
I don't think we had any lightening friday night. Anyway a voltage spike should have killed the fuse in the powerbar, right?
SniperREX wrote:Anyway a voltage spike should have killed the fuse in the powerbar, right?
Maybe not if you designed the powerbar would you know what people would plug in? So if a large TV was plugged in during turn on it may blow fuse so this fuse maybe large and maybe a slow blow type.
Slow-blow used for a large amperage start, Quick-blow used for electronic equipment not TV's with a heavy start up current.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Not always.
A 'problem' with some more modern equipment - receivers and DVD players - they never really shut all the way off, they go into a standby or 'sleep' mode. Gear that does that, it is usually a benefit to kill ALL power to the unit, IE, disconnect your power conditioners / ups units FROM the wall before replacing power cords.
If you don't, and especially if you plug into the unit LAST - you can risk the postive rails hitting just milliseconds before the ground connects - and have anything from a blown fuse, to a shorted board.
Cheers,
disneyjoe7 wrote:Maybe not if you designed the powerbar would you know what people would plug in? So if a large TV was plugged in during turn on it may blow fuse so this fuse maybe large and maybe a slow blow type.
I see.
I plugged the receiver in the outlet tagged "Receiver". Did the Monster Cable engineer screwed up
Maybe it's time to buy a powerful UPS just for the receiver.
RuSsMaN wrote:Not always.
Cheers,
Russ
Ok, thx for the info. That might explain the broken DVD player. But the receiver was already been hooked for about 5 months. I didn't unplugged it. It was in standby as usual.
Is it better to turn-off the powerbar when I don't use the receiver?
SniperREX wrote:
I really do like the AVS Forum. There are some people there that have a lot of knowledge. You just have to get passed the self-proclaimed "know-it-alls" at times.
Glad you fixed your problem.
Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
SniperREX wrote:I see.
Can't say, but feel different outlets will have different filtering so maybe. A fault of a Monster Cable engineer HELL YES (because of who they are MONSTER, I just don't care for) Other then that no you plugged in a different outlet so you are at fault here. Thats if it really made a difference not sure again about that.SniperREX wrote:Maybe it's time to buy a powerful UPS just for the receiver.
Big fan of UPS and used one for everything will be adding one back myself.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
