SRS 2.3 question
billbillw
Just a question for those who know for sure.
What is the nominal impedence on the early SRS 2.3, (the ones with pin/blade connector and the doughnut pucks in 2 of 6 mids)?
I suspect they are 6 ohms nominal but wanted to know for sure.
I know the SRS 2 was 4 ohms, and I know the 2.3TL is 8 ohms. Can't find anything published on the older 2.3s.
(There is a local pair that has had me curious for awhile.)
Post edited by billbillw on
Even my old SRS's are 4ohm.. they can be run on as little as 50watts. silly crazy i know... i'd never run them for long on that few watts. but they were disgned to handle as little as 50watts.
I actually ran mine for a few weeks on a old Yammie int running only 45watts. :eek:
PolkFest 2012, who's going>?
The 2.3's are 6 ohms nominal. The TL series is listed as, "compatible with 8 ohm outputs." However, they are 6 ohms nominal.Political Correctness'.........defined
President of Club Polk -
Thanks F1. That's what I thought...
