monopoles or bipoles
hey wassup team. i'm thinking of upgrading my four surrounds from monpoles to bipoles. right now i have four 2 way klh bookshelf speakers as my surrouinds. they give out great surround sound but i want something to fill up the back end just a bit more. good idea or bad idea.
Post edited by conqur on
Welcome Conqur!:) That is certainly something that you can experiment with just to see which you like best. It's pretty highly subjective. I have VonSchweikert surrounds and I can chose between dipole and mono and to me the mono sounds much better. You can always do a 30 day trial thingie and see if you like the sound of bipoles there.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
wingnut4772 wrote:Welcome Conqur!:) That is certainly something that you can experiment with just to see which you like best. It's pretty highly subjective. I have VonSchweikert surrounds and I can chose between dipole and mono and to me the mono sounds much better. You can always do a 30 day trial thingie and see if you like the sound of bipoles there.
D, can you elaborate on that. Just curious why you say the mono sounds better. I would think the dipoles would have a fuller effect. Are the dipoles more full but not as clear/precise?UNIVERA
Historic Charleston SC
2 Channel:
SDA-SRS's RDO tweets
Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
Anthem Pre 2L w/E.harmonix platinum matched 6H23's
CDP- NAD C 542
HT setup:
AVR: NAD T 773
Rears: Polk LC80i
DVD: Toshiba 3109 dual tray
Subs: Velodyne and M&K
T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
Conditioner: Panamax M5100EX
Master Bedroom Sony 40KDL-XBR3
"I love it when a plan comes together." Hannibal Smith, The A-Team -
welcome to the forums. Grab 2 sets of Polk F/X's, set the side ones to dipole and the ones in back to bipole.
univera wrote:D, can you elaborate on that. Just curious why you say the mono sounds better. I would think the dipoles would have a fuller effect. Are the dipoles more full but not as clear/precise?
In my room , when I select dipole it all sounds like mush to me. Monopole sounds much better and clearer with my system. Because my surrounds are angled like dipoles and against the wall I still get some dispersion- a little. Also music is ten times better.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
i'm glad to be apart of this forum, but i feel uninformed and left behind with all these polk fans around here. my only polk product is my sub.
You should change your lack of polkness immediately!!!!!!!!!! The audio Gods will smile upon you.
I have tossed this bi-pole/di-pole thing a bit and settled on di-pole for the sides and bi-pole for the backs. Seems to me when there is a Back Surround track on the disc most of it is transient sounds, overhead gunshots, copters and the like. Well actually I dont use switchable back speaks, but if I did I would set them to bi-pole.
RT1 -
yes i know i need to invest more in polk the sub i have is awesome. i love it..nice tight, full bass. i was thinking of upgrading my entire speaker system to polkaudio. but what is up with the svs subs. i keep reading about them on this forum.
