Originally posted by danger boy what does it cost if you can't have a receit for the speaker any more? just curious. all my speakers are fine. but wanted to know anyway.
well the warrenty on the speakers are 5 years i think. And if you have them registered with POLK. You should be ok even without the recipt since everything is on file.
Polk RT600i's
Polk C245i Center
Jbl surrounds (need to find F/X300s) info anyone???
Harmon Kardon AVR80
Sony Processor SDP-E800
Toshiba DVD SD-1200
Sony Minidisk MDS-JE320
Monster 400MKII Interconnects
--all protected by PANAMAX 1000+
Someone buy my JBL 12" sub so i can buy a new polk... LOL
in need of a dusting but all the same it works great... I'll most likely expect to much for it though im good that way, ask Russman, hehe Just kidding... If i got the person wrong sorry...
Originally posted by HBombToo This is how I created my own center channel rack for the Sony 57". I tried...
I like your stand for the center.... Where did u get the items to make it?
Polk RT600i's
Polk C245i Center
Harmon Kardon AVR80
Toshiba DVD SD-1200
I had a 7 tier book shelf but was worried about the baby pulling it over and took it down. I used 1 of the shelves and connected shelf brackets I found in KMart. The brackets are connected upsidedown for the lift and its been like that ever since. The bigger the shelf bracket the more angle on the speaker.
faster100 have you thought of keeping the JBL sub and also adding a Polk sub? running dual subs? I've toyed with that idea.. really want to hear what it would sound like in my set up. i've been looking the HSU subs. i think the VFT 2 is the one.
Polk C245i Center
Harmon Kardon AVR80
Toshiba DVD SD-1200
Good job
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Polk C245i Center
Harmon Kardon AVR80
Toshiba DVD SD-1200
Hope that explains it?
HBomb
