PCM Audio?
millerman 3732
When should PCM be used?
Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Post edited by millerman 3732 on
As in Pulse Code Modulation vs. DSD in the context of Codec methods?I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
I'am sure I don't know what your talking about
, I seen the setting on many of the DVD players that I have owned and wondered when PCM should be used instead of bitstream. Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Polk Signa-1 Surround bar -
ah, I see. Here is what recommended:
Bitstream/PCM: Set audio output to bitstream. The only reason you wouldn’t want to use bitstream is if you’re not using the DVD player’s digital audio outputs. Almost all DVD players have PCM set as default, PCM will not send Dolby Digital or DTS to the receiver even if the DVD player is compatible with those audio formats. Countless new DVD player owners will listen to stereo PCM transmitted to their receiver over digital outputs, wondering why the receiver isn’t detecting Dolby Digital or DTS.
Translation: if you are using coax/optical, then choose bitstream, if you are using RCA, then PCM.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
How about when I 'am using the 5.1 analog, PCM then to?Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
that I am pretty sure don't really matter, since 5.1 is in pure analog space, so the option is irrelevant. Assuming you are talking about SACD/DVD-A multi-channel playback.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
when I watch an HD DVD I use the 5.1 analog output so that I can get DD+ to my receiver with out the receiver converting it to DTS (so I think) and wondered if that PCM would be a better choice in stead of bitstream in this situationCasey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
When I watch an HD DVD over HDMI I have to choose PCM in the menu.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
hey wingnut, FYI This settings relates to the optical output; it shouldn't affect analog or hdmi, this what I was told over at Hometheaterforum, check this outhttp://www.hometheaterforum.com/htf/showthread.php?t=240876Shoot the jumper.....................BALLIN.............!!!!!
Oh Ok..missed thatSharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Another example of when you should use PCM is if you're using a DVD player as a transport with an external DAC in a 2 ch system.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5.
