upgrading to lis15s?
  • okiepolkie
    okiepolkie Posts: 2,258
    edited August 2006
    The 1075 would be great for LSi7's, but the 15's need more power.
    Also, (and this is a personal opinion) look into something besides the Monster Cable speaker wire. Look at www.signalcable.com, or something similar.
    Tschüss
    Zach
  • andyisc00l
    andyisc00l Posts: 35
    edited August 2006
    Heck I don't mind putting in 250-300watts as long as there isn't an increase in risk........
    have people reported damage from more watts and has polk ever commented on using more watts?
  • andyisc00l
    edited August 2006
    only reason I'm looking at monter cable is cuz I can get $200 rcas for $30
    and the rated power on the lsi15s is 250 watts RMS max, why would they say 250 max and then 200watts isn't enough power?
  • ohskigod
    ohskigod Posts: 6,505
    edited August 2006
    there is a general school of thought that the LSi's reward you for more power. I experienced that myself, hence the silly amount of power I'm sending to them.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • andyisc00l
    edited August 2006
    can anyone confirm that they've used around 300watts @ 4ohms for the center channel for over 1 year!? I'm just scared ! lol why would they say 200watts max when 300 is ok! That's pretty stupid of them to do...!
  • andyisc00l
    edited August 2006
    And either the oultaw 7500 or the rotel 1095!?!? Which one?!?!
  • cheddar
    cheddar Posts: 2,390
    edited August 2006
    If you can get monster stuff at a discount, why not just get an mpa 2250 and 3250 to drive your system. That's what I have now for my LSis and they rock. It's 400W at 4ohms and yes I've had the set-up over a year without blowing the speakers. But if you really understood what usually blows speakers, you wouldn't need this assurance.
    A receiver that loses control of the power at 30W can blow your speakers far more easily than an amplifier that is large and in control all the way up to 400W. In everyday listening, you probably won't go above 10-20W at very loud volume levels. If you abuse your ears, you may be able to get it up past 100W maybe 200W at ear bleed/deafening levels. So in reality, the real danger would be trying to push a 100W receiver to loud volume when it would probably clip below that rating.
  • andyisc00l
    edited August 2006
    lol well they still have a combined retail of $5500:-p
    I'll probably just find an outlaw or rotel that puts out 300+ watts rms @ 4 ohm...that should be enough right?!?! I sure hope so..
    maybe I'll try to find some i can find the $2500 for $700 now new, if I could find the other one for $1000 it might work...I've heard rave reviews... bah $2500 for the both thats too much money :-(
  • McLoki
    McLoki Posts: 5,231
    edited August 2006
    I have had my setup for a year and was running LSi7's for my front speakers for a year before that.
    Amp is rated at 500wpc@ 4 ohms W/ 1100 watt peaks.
    I did call polk before I purchased my amp and they told me that they had only recieved a couple of calls of people blowing speakers from to much power. They recieve calls all the time from people running smaller AVR's that blow speakers.
    You will be fine. This is one case where size really does matter. :)
    Michael
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2006
    Let me put it this way Andy. If you blast your speakers with all that power, your eardrums will rupture before your speakers blow!:eek: Then it won't matter how loud you play them!:D
  • andyisc00l
    edited August 2006
    If I were to buy retail speakers then polk is the way to go..but I've been hearing about "DIY" kits...does anyone have any ideas on how good a $1000 kit will sound (thats how much I'll pay for polk lis15s)...?
  • andyisc00l
    edited August 2006
    Wow 2500 watts rms @ 4 ohm for 5 speakers is ridconcoulous..lol how does it sound? I'm guessing pretty friggen good..
  • McLoki
    McLoki Posts: 5,231
    edited August 2006
    The amp is awesome. To be honest, it is just revealing the next weak link in the chain. For me that is my pre-amp (receiver). I have heard my system with a decent pre-amp it is unbelievable.
    I have a passive subwoofer that runs off the 6th channel of the amp so I am actually using it as a 3000-watt amp. (If I turn it on and off to many times to quickly (like four times in less than 2 min or so) I blow the 20-amp breaker it is plugged into in my house).
    Like someone else mentioned though. I rarely use that much power. I would guess on average I am only using 2-10 watts (if that much). The difference is when there are peaks (explosions and such), many amps and AVRs will distort. Mine doesn’t.
    Michael
  • faster100
    faster100 Posts: 6,124
    edited August 2006
    I doubt that thing is getting anywhere near 2500 watts or 3000.. peaks i can see in the hundreds, maybe.. I'm sure its a nice amp but that kinda wattage would blow just about any speaker
    edit: i didnt see where he was adding each channel together to get to the 2500 watts,
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • McLoki
    McLoki Posts: 5,231
    edited August 2006
    SPECIFICATIONS-
    Output Power....... .350 WPC/8 OHMS (typ. 450W)
    ...........................500 WPC/4 OHMS (typ. 670W)
    ...........................1000 WATTS MONO (1400 @ 4 ohms)
    THD..................... <.015% (full power 15-20Khz)
    TIM..................... <.015% at full rated power
    Freq. Response...... 2-180 kHz + 0, -3 dB
    Input Imped.......... 47K Unbal, 15K Balanced
    Configuration......... 3,4,5 or 6 Channel
    Dynamic headroom... >3.5 dB! (Typ. 850 watts @ 8 ohms, 1100 watts @ 4 ohms)
    Peak Current......... 120 amps per channel (720 amps total) .1sec pulse, .5 ohms
    Hum/noise............ -110 dB unweighted
    Damping Factor .....Over 1000 (!) (10Hz-1kHz)
    Cooling ................Convection w/ on demand silent fan
    Weight................ 70 lbs
    Dimensions ...........19"Wx8"Hx16"D
    AC Voltage........... 100,120,220,240
    Recom.Service...... 20 to 30Amps-100,120V (will run adequately on 120V 15 amp service). ...........................20 to 30 Amps-220,240V
  • faster100
    edited August 2006
    I don't doubt its a nice amp.. but specs are specs..
    did you see the page on receivers online, half didnt do half of what the specs said.
    and the linked page to your amp, they state you must have 1100 watts for peaks even if you use 10 watts normally.. in HT.. so we have all had it wrong useing 100 -300 watts :D
    No big deal, was just saying i doubt it ever gets near 500 watts for each channel im sure.. all channels on.
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • McLoki
    McLoki Posts: 5,231
    edited August 2006
    You are right. The specs are just company created specs, no better or worse (from an accuracy standpoint) than any other companies specifictions.
    With my 88db efficient speakers, they are only 76db efficient at my 12-14 foot listening distance. (every time the speaker to ear distance doubles, the efficency drops by 6 db) This does not take into effect coupling of multiple speakers or corner loading the system (both would increase the efficiency of the speakers)
    1 watt - 76db
    2 watts - 79db
    4 watts - 82db
    8 watts - 85db
    16 watts - 88db
    32 watts - 91db
    64 watts - 94db
    128 watts - 97db
    256 watts - 100db
    512 watts - 103db
    1024 watts - 106db
    2048 watts - 109db
    4096 watts - 112db
    8192 watts - 115db
    As you can see, I cannot play at reference level without blowing my speakers. (or at least clipping the amp) The loudest I have ever tried to play is -6db. Once you get over 100db though, the power requirements are pretty huge and get bigger fast. (of course this is for peaks, not continuous ratings...)
    Michael
    Edit - Reference level is listed as 105db peaks from any channel and 115db peaks from the LFE channel (which, in my case, is also running off my amp) all measured from the listening position.
  • Ruin
    Ruin Posts: 59
    edited August 2006
    Just because you tosss a couple of hundred watts per channel amp at the LSis doesn't mean you need to use them. When people are rocmending a powerfull amp they are recomending it because driving an amp at 50% of its rated power gives less distortion than running it at 90% of its rated power. You pull 100watts/channel out of a 110watt/channel amp you are going to hear distortion in all likelyhood compared to pulling that same 100watts.channel of of a 200watt/channel amp.
    So, dont USE all that extra power because yes, there is a limit to what the speakers can stand. However, given the limits of how loud you are likely to really listen to them, you are more likely to blow them with heavy distortion from an underpowered system than you are from overpowering them at low distortion.
    Ruin
    Denon AVR4806CI
    Denon DVD3930CI
    Panamax 5500-EX
    Polk LSi25 mains/subs
    Polk LSiC center
    Polk LSi9 Surrounds on Custom Skylan stands
    Mitsubishi WD-65831
    Audio Art IC-1 Interconnects
    Audio Art SC-5 Speaker Wire
  • Drumingman
    Drumingman Posts: 348
    edited August 2006
    Let's all say it again.:rolleyes:
