tweeter problem
schmilnik
schmilnik Posts: 44
edited August 2006 in Speakers
hey guys I have the rti 6s and i think i blew the tweeter. Their is a static sound coming from my 6s and my csi5. So i sent them in today to polk to have them look at them. Is this common and what could I have done to do this. I was running the rti6s the csi5 and my sub through a hk avr335. Thanks for any help!
Post edited by schmilnik on
  • Jim Shearer
    Jim Shearer Posts: 369
    edited August 2006
    Can you give us an idea about how loud the system was playing & for how long?
    The majority of blown drivers result from running the amp into clipping, which means the speakers are receiving square waves that endup w/ too much power into the tweeters. (And AVRs w/ switching power supplies have little or no 'head-room'.) It takes a lot of clean power to blow a good driver.
    Cheers, Jim
    A day without music is like a day without food.
    F1nut Posts: 51,700
    edited August 2006
    I agree with Jim and I'll bet you had the tones controls tweaked too.
  • schmilnik
    schmilnik Posts: 44
    edited August 2006
    Cheers, Jim
    I was listening to it aout 3/4 volume and for about 30mins. And the tones and everyting was equalized. And what do you mean by head room? Thanks for you help.
  • Schwingding
    Schwingding Posts: 363
    edited August 2006
    I have a brand new pair of RTi10s with a blown tweeter as well. I have not played anything at all very loudly, to be totally honest, no where anywhere close to my system's capabilities. I'm very surprised, but know it is not an unheard of situation. Tweeter will replace the whole unit with no questions, but still....
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
    F1nut Posts: 51,700
    edited August 2006
    And there we have the answer. Turn it the eff down and turn off the tone controls or at least leave them FLAT.
  • EricBurg
    EricBurg Posts: 64
    edited August 2006
    I would say that if you have 3 speakers with blown tweeters, then you had the volume way too high for you amplifier to handle the signal.
    Eric
    __________________
    Pioneer 1015
    Rotel 1080
    Rotel 1075
    Rti10: L/R
    Rti5: C
    Rti6: LS/RS/LSB/RSB
    SVS pb10-isd
  • univera
    univera Posts: 848
    edited August 2006
    Power in reserve, for large cymbol crashes, etc. Dynamic, explosive portions of a performance will require your amp section to reach down for some reserves. If you are already maxing out your your amp's capabilities (at 3/4 volume, you are and are likely distorting) and the music requires something dynamic, then you have nothing in reserve. Even if your amp section has protective circuitry that "rolls off" the signal to keep it from sending damaging wave forms, it still has nothing left to give at that kind of volume setting.
    Dedicated amps generally have more headroom and some designs are efficient at only giving the music the amount of power/current necessary rather than the whole capability all at once. This keeps the equipment running cooler as well as saves some juice for parts of the performance that require more draw. This may not be a perfect analogy, but it is similar to VTEC engines where only part of the engine is churning but it can run at full strength when called upon because it previously was only using what was needed at the moment.
    Your amp at that level is using every bit of what is required and is likely lacking what is truly needed, therefore compromising the signal quality and sound and concurrently damaging your speakers. The only way for it to keep playing is to modify the wave forms of the music as it can't reproduce them accurately. Lot's of heat may be building up. After that point, your unit may clip or cutoff. This is a layman's explanation, and the only way I can explain it. As always, there are more experienced members, so if I am off base at all, I will be corrected.
    Most people recommend keeping the volume knob at 11:00 or so. You are usually adding distortion as you approach the 12 spot.
    UNIVERA
    Historic Charleston SC
    2 Channel:
    SDA-SRS's RDO tweets
    Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
    Anthem Pre 2L w/E.harmonix platinum matched 6H23's
    CDP- NAD C 542
    HT setup:
    AVR: NAD T 773
    Rears: Polk LC80i
    DVD: Toshiba 3109 dual tray
    Subs: Velodyne and M&K
    T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
    Conditioner: Panamax M5100EX
    Master Bedroom Sony 40KDL-XBR3
    "I love it when a plan comes together." Hannibal Smith, The A-Team
