LFE channel
univera
Can someone explain what an LFE channel is besides a low frequency channel? Since I am am newly getting back into HT, I don't recall LFE being discussed several years ago. My older subs don't have a specific LFE connection (although I read Ken's sticky above.) Is LFE a newer way/name for sub channel that is better or did I just miss it all along?
UNIVERA
Historic Charleston SC
2 Channel:
SDA-SRS's RDO tweets
Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
Anthem Pre 2L w/E.harmonix platinum matched 6H23's
CDP- NAD C 542
HT setup:
AVR: NAD T 773
Rears: Polk LC80i
DVD: Toshiba 3109 dual tray
Subs: Velodyne and M&K
T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
Conditioner: Panamax M5100EX
Master Bedroom Sony 40KDL-XBR3
"I love it when a plan comes together." Hannibal Smith, The A-Team
2 Channel:
CDP- NAD C 542
HT setup:
AVR: NAD T 773
Rears: Polk LC80i
Post edited by univera on
To my knowledge LFE is the sum of low frequencies from all the channels below your crossover. Let's say your crossover is 80Hz then all the freq 80Hz and below in the sound track will be directed towards you LFE channel.
Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
Sub - JTR Captivator S2 (Dual 18")
Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35 -
It is my understanding that the LFE channel is the Low Frequency effects channel that is in a movie soundtrack. It is separate from any bass you may send your sub via a crossover setting in your controller.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Darla, bingo was his name..I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
You can provide low frequency to sub in multiple ways.
1. Use a sub out from receiver and connect it to LFE input on Sub. In this case Receiver makes sure that sub out has proper Low frequency signal based on your speaker settings.
2. Use a line out from your receiver and connect it to line in on you sub. In this case you are supposed to provide a full range signal to Sub and internal cross over in your sub extract the low frequency signal out of it.
The later is preferred connection on all new gears. Some times your sub doesn’t have LFE labeled input, but has a crossover disable switch to turn off internal crossover. If your sub doesnt have that and you are still hooking it up to your Sub-out on your reciver then you should turn the variable crossover all the way up to minimize the effect of double crossover in signal chain.-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
wingnut4772 wrote:It is my understanding that the LFE channel is the Low Frequency effects channel that is in a movie soundtrack. It is separate from any bass you may send your sub via a crossover setting in your controller.
Yupper, you can add things to the LFE channel via crossover, but those aren't actually a part of the LFE channel, they're added on. Ideally, you have all speakers handle 20hz-20kHz, and the subwoofer gets just the LFE and nothing crossed over. -
univera wrote:Can someone explain what an LFE channel is besides a low frequency channel?
It's a pain in the ****, that's what it is. -
Mjr7531 wrote:Yupper, you can add things to the LFE channel via crossover, but those aren't actually a part of the LFE channel, they're added on. Ideally, you have all speakers handle 20hz-20kHz, and the subwoofer gets just the LFE and nothing crossed over.
It would seem then that one would ideally need to two subs or all channels capable of handling full range frequency. Is there a seperate "LFE out" on the receiver? If you don't have full range speakers at all positions, then one would obviously have to send sub frequencies to a dedicated subwoofer (or I suppose the mains could handle that, but most instances would be calling for a sub.) In that scenario, if LFE is its own deal, then another sub would be needed for LFE frequencies. Seems like alot of work. Why can't a sub handle both duties? I don't see the need for a dedicated LFE channel/sub.UNIVERA
2 Channel:
CDP- NAD C 542
HT setup:
AVR: NAD T 773
Rears: Polk LC80i
"I love it when a plan comes together." Hannibal Smith, The A-Team -
Your receiver does all the math. LFE is technicaly the .1 in 6.1
When they mix a multi-channel soundtrack, they can send whatever they want to the sub via the low-frequency effects (LFE) channel.
Your receiver adds any low frequencies from channels set to "small" (or freqs below your cross-over point). Since bass is omni-directional, your ear can't tell that the lows are coming from a different location than the accompaning mids.
I've considered adding a second, smaller sub to my setup. I figured that if I run the mains to it and set the speaker size to "large", it would take some of the work off my bigger LFE sub. any thoughts on that? -
The sub out on a receiver/processor will send the LFE channel and any bass below the selected crossover freq (in the receiver/processor) for any channel set to small.
Even with large, relatively bass capable speakers, I've found that I get more impactful bass for 5.1 movies setting all speakers to small with a 80 Hz crossover in my receiver (letting the sub handle the LFE and bass below 80 Hz from the other channels). There is no need for multiple subs, assuming your sub is up to the task.
For 2 ch music, however, I still prefer to run my mains full range with no sub (not even using the receiver in my set-up).5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5. -
univera wrote:Can someone explain what an LFE channel is besides a low frequency channel? Since I am am newly getting back into HT, I don't recall LFE being discussed several years ago. My older subs don't have a specific LFE connection (although I read Ken's sticky above.) Is LFE a newer way/name for sub channel that is better or did I just miss it all along?
LFE= Light Fixture Extractor
LFE= Large Friggin' Enclosure
LFE= Look For Earmuffs
LFE= Like Feeling Earthquakes
