New Center Channel
Early B.
Early B. Posts: 7,900
edited September 2006 in Speakers
As I near the completion of "rolling" my HT speakers, I picked up an Aad 2002 speaker for use as a center channel. My goal is to acquire the highest quality speakers within my price range so I can refrain from trading out speakers in the future. In the past, I've always settled for lesser speakers due to budget constraints. I haven't pursued speakers I've really wanted until now.
Aad is not well known in the USA, but the designer is Phil Jones, who along with Joseph D'Appolito, are the most noted speaker designers in the world.
OK, back to the 2002's. First of all, the speaker weighs 62 lbs!!! That's partly because it is lined with lead to make it totally inert. Second, it is a great looking speaker, despite what my wife says. Third, the speaker binding posts are huge!! They're definitely overbuilt. Fourth, all of the writing on the speakers is engraved. Fifth, the speaker is rated down to 27 Hz.:eek:
Here are some pics:
"God grooves with tubes."
Post edited by Early B. on
  • PolkThug
    PolkThug Posts: 7,532
    edited August 2006
  • polkatese
    polkatese Posts: 6,767
    edited August 2006
    interesting look and design. nice setup, btw.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • Early B.
    edited August 2006
    Forgot to mention how it sounds -- WONDERFUL. No need to upgrade.
    Now I'm on the hunt for some fronts. Maybe a pair of Aad 2001's or the floorstanders (Aad 2003). Maybe Von Schweikert VR-1 or VR-2's. I dunno yet. Just gonna be patient for now (yeah, right). Haven't decided on floorstander or bookshelf, although I'm leaning towards bookshelf for the sake of convenience (they can be moved out of the way when not in use).
  • faster100
    faster100 Posts: 6,124
    edited August 2006
    they sorta echo the import tube gear look... I like em, don't care so much for the grill.. looks nice on the rack
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • Early B.
    edited August 2006
    I took the grille off and the speaker looked naked without it, so it went back on. The grille is part if its high end appeal, IMO.
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited August 2006
    Gorgeous:eek:
  • AndyGwis
    AndyGwis Posts: 3,655
    edited August 2006
    Nelly would be proud of that grill.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Skynut
    Skynut Posts: 2,967
    edited August 2006
    I dig it and I dig the grill.
    Later for an up grade you can get diamonds mounted in the grill. :D
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • tecmo04
    tecmo04 Posts: 421
    edited August 2006
    wow. Now thats a piece of art! beautifull!
  • Willow
    Willow Posts: 11,218
    edited August 2006
    Nice speaker, but I'm not a fan of the grill.
  • bert26
    bert26 Posts: 320
    edited August 2006
    Hey Early,
    That is a thing of beauty! Looks almost scultpted to me. I like the grill as well - you can always electrify it to keep prying hands away.
    Congratulations on the purchase.
    Chris
    HT Rig
    Polk SDA SRS 2.3tl - Anthem 2 SE
    Polk CSi5 - Adcom 555
    Polk Monitor 30 - HK DPR1005
    SVS PB12 ISD/2
    Denon DCD-1500II
    Sony SXRD 60"
    ShengYa CS-10
    Basement Rig
    Polk SDA SRS2
    Carver 1.5t
    Carver C2
    Technics SLD202
    Some Other Sony DVD/CDP
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited August 2006
    I believe Phil Pearsall has aad's as well and really loves them.
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • Joey_V
    Joey_V Posts: 8,600
    edited August 2006
    Looks pretty damn solid if you ask me.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited August 2006
    Fugly, imo - but if you dig 'em, who am I to tell you any different.
    Looks very white-van'ish to me. I've never seen support rings on drivers that small. Looks a lot like the larger pioneer / radio shack drivers of the 80's (10, 12, and 15 inch) where the paper cone needed extra support for long throws - hence the added support rings in the cone. While o-k for bass, that's HORRIBLE for midrange applications.
    You don't need lead to make a speaker inert, you need dense materials in the build, and proper bracing - a few pounds of lead in the cab don't keep it from flexing.
    You've had better, you deserve better.
    Cheers,
    Russ
  • Early B.
    edited August 2006
    Cheers,
    Russ
    Russ --
    Since it's tough to look at a blurry picture and assess the quality of the drivers, perhaps a description of said driver will help you out:
    "The woofer has a hard anodized aluminum cone and dust cap with a unique cone geometry which allows it to stay pistonic in its operational band and produce a very flat frequency response. Above this frequency range at 2.6 kHz the acoustic output falls off rapidly at 18db/octave so that all cone breakup modes are severely attenuated even without filtering.
    The woofer frame is die-cast from magnesium aluminum alloy. The frame has excellent rigidity and heat sinking characteristics. It has additional ventilation for heat generated in the voice-coil.
    The oversized 34mm voice coil has substantial power handling. It is wound directly onto a 0.3mm black anodized ventilated aluminum coil former. This former is bonded to the cone using specifically designed heat conducting adhesive so that the whole coil-former and cone assembly acts as a heat radiator. This means the operating temperature of the voice-coil is reduced to its absolute minimum, giving are far greater dynamic range.
    The large and powerful magnet assembly is shielded. It also has a 3mm lead disc fitted to it to reduce mechanical resonance.
    The rubber surround and large excursion spider/damper will not fatigue under normal operating conditions. These components will actually improve with age and it is recommended that the speakers are run in for 200 hours before they start to sound at their best."
    To clarify, here's what the manufacturer says about the lead:
    "Lead sheet 3mm thick is applied to each panel before assembly to further reduce panel coloration."
    VR3 Posts: 29,394
    edited August 2006
    Im not sure what to think...
    It looks hardcore. Dont really dig the bolts in the side, the finish, or the grill - but regardless...it looks hardcore. And Im sure it sounds great...
    But... yep, not sure what to tell you here.
  • Joey_V
    Joey_V Posts: 8,600
    edited August 2006
    Regardless of the center... why are you assembling a hodge-podge of speakers for your HT?? This doesnt make any sense as this completely goes against setting the right timbre across the whole front stage.
    Exactly what is it that you are trying to accomplish?
  • Early B.
    edited August 2006
    The timbre matching thing is cool, but overrated, IMO. I've had a couple of systems that were timbre matched and others that weren't, and as long as the system is calibrated and the tweeters aren't totally different (i.e., Klipsch horn and ring radiators), it's cool.
    In this case, though, if I could find the matching bookshelf speakers at a great price, I'd jump on 'em, not necessarily for timbre matching, but for SQ and aesthetic purposes. Aad does business primarily overseas, so they rarely show up on the used market stateside.
  • Early B.
    edited August 2006
    I calibrated my system and watched a demo DVD so I could evaluate the new center channel. So far, I am very pleased. It sounds better than any other center channel I've had. It is very clear and more detailed than what I have been accustomed to hearing. The biggest benefit is the bass. Damn! The bass is awesome. It appears as though I added a subwoofer to the front soundstage.
    This speaker is rated down to 27 Hz. I don't know if it goes that low or not, but it fills in the bass quite well. I have always been a proponent of "bass all over the place," no matter how big and bad your subwoofer is. This center channel substantiates that concept. Now I gotta get my hands on a pair of bookshelf speakers that dip into the mid 30's or lower, and I'll be good to go.
  • RuSsMaN
    edited August 2006
    Get the matching mains -> http://www.lightav.com/home/aad/2000.html
    If ya dig it, dig it!
    Cheers,
    Russ
  • faster100
    edited August 2006
    those are some funky designs but i like the sub..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Early B.
    edited August 2006
    Cheers,
    Russ
    Thanks for the link. Gotta buy used, though, 'cause them **** is expensive. Don't like the gaudy stands.
    Perhaps I can convince Pear to sell me his 2001's. Hmmm.
  • Early B.
    edited August 2006
    The Aad sub has gotta be incredible. Goes down to 18 Hz with two 8" woofers. Wow.
  • danger boy
    danger boy Posts: 15,722
    edited August 2006
    that's a LOT of bling for just one speaker.. very interesting.. i've never seen anything quite like it before.
    enjoy
    PolkFest 2012, who's going>?
  • Early B.
    Here are a couple of pics of the crossover. There's nothing special about the quality of the crossover components, although it's interesting how they wrapped two of the inductors around the port. The MDF is at least 1" thick. The interior has a few sheets of lead, but is not lined entirely with it. The drivers (not pictured) appear to have large motor structures.
  • Shannon W.
    Shannon W. Posts: 568
    50" Samsung Plasma
    Sony STR-DA4ES "use as Pre/amp"
    Pioneer Elite DV-45A DVD Player
    DLO HomeDock Deluxe iPod docking station
    Directv HR20 Sat. Receiver in black
    Sunfire Cinema Grand 7 Signature Amp
    Monster Cable AVS2000
    Monster Cable HTPS 5100 MKII
    Polk LSi 9's Front R/L
    Polk LSiC Center
    Polk LSiFX R/L Surround
    Polk LSi 7's Rear R/L
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
    Click Here To View my Rig
  • Early B.
    Wow.
    Those 2001's are gorgeous. Too bad they're in Australia. With my luck lately with shipping, they'd have to be indivdually triple boxed, crated, placed on pallets, flown on a private jet, then hand carried by the secret service to my house, and meticulously unpacked by a team of archeologists.
  • pearsall001
    pearsall001 Posts: 5,241
    Yo Early!!!
    What are you nuts??? No way I'm selling my AAD 2001 monitors. They're just too damn good. If you know anything about Phil Jones you know exactly what you're in store for with his designs & sheer performance. I just had a fellow I met on Auduocircle over last week for a nice visit. He said up front he wasn't a fan of small monitors. Well when he left I had to carry his jaw to the car for him, it was still dragging on the ground after he had a listen. Needless to say he changed his mind about small monitors. Oh & by the way the site Russman gave is an un-authorized site. The AAD site is - AADaudio.com. Me thinks I won't be looking for speakers for some time to come, if ever.
    Cheers,
    Phil
  • Lsi9
    Lsi9 Posts: 616
    As far as matching the 3 front speakers of different brands, I thought the most important attribute while matching them is db(s) of sensitivity, can someone confirm that?
    Audio Physic Scorpio II
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • Shannon W.
    I Still love those stands. "Industrial but yet elegant"
    50" Samsung Plasma
    Polk LSiC Center
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
