FXi50
peteran
peteran Posts: 141
edited October 2002 in Speakers
I own the RT55, CS400 and RT25 speakers, I'm looking to replace the rt25's(surrounds) with the FXi50.
Question is, will it be a big difference in timber matching? I know the FXi50 has a 1" tweeter and 6.5" driver, or should I look for the FX500?.
Post edited by peteran on
  • scottvamp
    scottvamp Posts: 3,277
    edited October 2002
    FX500i would be nice but the FXi50 is basicly the same speaker. It won't be a problem. Mixing a front stage (main/center) would be a little more tricky. 1" tweeter and 6.5" driver matches your front stage exactly. That is what u want to do. To get technical your rt25's were the miss match. The FXi50 will work great - good upgrade. ;) Welcome to the forum!
  • mantis
    mantis Posts: 17,056
    edited October 2002
    I don't see a major problem with that......if you can find a pair of fx/500's or even fx/500i's you'll be cool which ever way you go.
    The older models match perfectly and probably will cost less....
    Dan
