coax cable as speaker wire?
    F1nut Posts: 51,760
    edited August 2006
    Fear not. Just like the **** that passed as he flexed his anal ****, he's gone with the wind.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited August 2006
    Well, the best we can hope for is QQ gets a bit wiser with time.
    It was short it was not fun but it was entertaining.
    Another bag of **** who's neck is red.
    But I could really use some help with the whole lain, laid, lay'in and so on thing.
    Random thought---Given a circle would you jump off the edge or edges of it????
  • HBombToo
    HBombToo Posts: 5,256
    edited August 2006
    I'll take the edge... Oh, wait there is another won, Oh and yet another one but is it won or one. Sine I are an en"JIN"eer I'll just use 1:o
    ***WAREMTAE***
  • read-alot
    read-alot Posts: 812
    edited August 2006
    Tell me about it, I needed help with this
    "there is a difference between "your" and "you're"
    thing. :) But I am wiser with time.
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
    SCompRacer Posts: 9,112
    edited August 2006
    I would require more information before attempting to answer that question. How wide is the edges?:D
  • reeltrouble1
    edited August 2006
    The width of the edge is directly proportional to the length of the foot.
    useless fact---strength is the longest word in the English language with one vowel.
    RT1
  • TheReaper
    TheReaper Posts: 636
    edited August 2006
    The strengths of that statement are irrefutable.
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • pancho681
    pancho681 Posts: 6
    edited August 2006
    How bout them dodgers!!
    In the words of a great man(sarcastilly) in our era "cant we all just get along"
    :D
  • BionicSniper
    BionicSniper Posts: 4
    edited September 2006
    i like monster cable. But for interconnects i go for homegrownaudio pure silver wire.
  • SKsolutions
    SKsolutions Posts: 1,820
    bknauss wrote:
    Actually, that's not the problem for baseband signals (20-20kHz). I assume you're getting into the transmission line effects which isn't a problem at all in audio. The problem with using Cat5 cable is the lack of cross section of copper. More cross section = ability to pass more current. Depending on how much copper is in Cat5 cable and the distance of the cable, you're going to have a drop in voltage. That's not good for sound. It can be good for line level connections though (interconnects).
    Actually, no. Skin effect in regard to solid core vs bundled strands.
    -Ignorance is strength -
  • clh
    clh Posts: 3
    edited December 2008
    mis post...tried to delete
