A few noobie questions
irregularjoe
irregularjoe Posts: 23
Hi. New to the forum and new to Home Theater.
I just bought a Polk RM 6900 package and an Onkyo TXSR603 along with an Onkyo DV-CP702 DVD changer. My first try at 5.1 sound. Always been a stereo kind of guy.
Anyway, I'm taking down my Bose Accoustimass 5's and the "sub woofer" that really insn't and installing this new system.
I'm going to use the existing #14 speaker wiring for the surrounds and add new #12 for the fronts and center, and digital audio cable for the sub.
Should I use banana plugs as connectors or just bare wire? Also, are banana plugs used on the speaker or just the amp? I haven't taken them out of the box yet as they are a gift to my S.O.
Another question: My receiver is 7.1 but my setup is going to be 5.1.
Should I set up the smaller sats as "surround" or "rear"?
Also does anyone have any experience with these speaker mounts?
eBayISAPI.dll?ViewItem&item=160017311260&sspagename=ADME:B:AAQ:US:1#ebayphotohosting
They are only $12 a pair compared to the $50 mounts at BB and CC. I don't want junk however.
Thanks for reading.
Joey
Post edited by irregularjoe on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited August 2006
    Welcome to the forum! Use whatever method of attachment you prefer. Most don't bother with bananas unless you are going to change out speakers often. If you already have them use'em. Many just go the slightly twisted bare wire method into the posts and find it to be good. Just make certain no stray wires exist.
    Check your manual for 5.1 speaker hookup. I would think that the surround/side hookups in 7.1 become rears in 5.1 and the rears are left alone.
    The mounts are most likely okay too, but I might try 1 pair first and make sure you get a solid mount into a stud.
  • irregularjoe
    edited August 2006
    Thanks for the info Dennis!
    No, i'm definately not going to be changing out the speakers regularly.:)
    I just thought the terminals would be a better connection. But being an electrician for the last 35 years, I should have known better.
    Marketing got me again.
    Joey
  • Dennis Gardner
    edited August 2006
    Lesser connections = lesser connection problems, as you know. But ohhhh aren't those 24k, cryogenic, factory broken in connectors pretty?;)
  • Willow
    Willow Posts: 11,231
    edited August 2006
    Welcome,
    You won't regret the change in systems. I went from a Bose to what I know have...slowly.. But amazing. My mother inlaw ended up with the old system and when I go over, I am thankful it's no longer mine.
    As for the naner plugs I use them as I like the clean look of the plugs, I use them in both speakers and AVR. I don't swap out speakers often..heck then only time is if I move the system around, major cleaning or buy new gear. But again I like the look of the plugs.
    I think you would need to hook them up as rears, that is my guess, but as mentioned as much as you may not want to read the manual, it'll be in there some where.
    Now go ahead, hook up that puppy, sit back and enjoy...heck take some pics and post'em up !
    One last thing, stick around !
  • Mike682
    Mike682 Posts: 2,074
    edited August 2006
    er.
    Thanks for reading.
    Joey
    Welcome to the forum Joe
    I would designate the smaller speakers as the rear/surrounds.
    EDIT: Just checked the manual and all five speakers have a -3db freq response of 100hz, so I guess it really wouldn't matter which ones are fronts or rears.
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • shack
    shack Posts: 11,154
    edited August 2006
    Willow wrote:
    I think you would need to hook them up as rears, that is my guess, but as mentioned as much as you may not want to read the manual, it'll be in there somewhere.
    Agreed
    If you get quality bananas and or quality terminated speaker cable there should be no connection problems. In fact, I find there are more issues with bare wire because of strands crossing terminals and so forth. All my speaker cables are terminated with bananas. Bare works ok and may be the best connection, but I like the ease and simplicity of the bananas. It is much easier to connect to the back of the reciever (most AVRs have crowded back-sides). I DO move speakers from time to time and the bananas are the way to go for me.
  • irregularjoe
    edited August 2006
    Thanks for all the advice.
    Joey
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2006
    Hi Joey & welcome! Congrats on the new gear. I fall in with Shack with liking the simplicity of banana plugs.
  • irregularjoe
    edited August 2006
    I ordered five pairs of banana plugs for the receiver. I can't find any info on whether the polk speakers accept them, so I'll use bare or pins there. Don't want to open up the box, but I'll see them tomorrow when my S.O. opens her gifts.
    I really got a crash course in Home Theater this past week.
    Optical audio cords, digital sub woofer cables, speaker mounts, Zone two, AV receivers, DVD changers, yada yada yada!!!!!
    As originally posted, I was always just a stero guy. A speaker on the left, a speaker on the right, plug it in, turn it on and that was it.
    Can't wait to hear and see it all together.
    Joey
    Oh, btw, the old Bose system and the old stereo receiver is going to be relocated to the bedroom. We've been without a stereo in there for some time now due to another Bose bookshelf speaker falling off the top of the armoire and breaking.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited August 2006
    I see a very nice stereo system in your future. That is the best thing about HT the spark it re-ignites in old audio hounds. Enjoy Joe.
    Now as for your other problem the regularity thing I have something that might just do the trick, just let me know.
    And most of all Welcome to CP..
    for the record
    bare wire is sexy cuz its nekid
    banana's are sexy cuz their shape fits snugly into a ??????
    spades are sexy cuz you get to pin them down
    see what's going on here..................
    RT1
    F1nut Posts: 51,749
    edited August 2006
    I see what's going on. You got laid last night.
  • univera
    univera Posts: 848
    edited August 2006
    I'm guessing the "wood" shed rig was playing at the same time....
    UNIVERA
    Historic Charleston SC
    2 Channel:
    SDA-SRS's RDO tweets
    Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
    Anthem Pre 2L w/E.harmonix platinum matched 6H23's
    CDP- NAD C 542
    HT setup:
    AVR: NAD T 773
    Rears: Polk LC80i
    DVD: Toshiba 3109 dual tray
    Subs: Velodyne and M&K
    T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
    Conditioner: Panamax M5100EX
    Master Bedroom Sony 40KDL-XBR3
    "I love it when a plan comes together." Hannibal Smith, The A-Team
  • reeltrouble1
    edited August 2006
