Newbie question about volume
phileth
phileth Posts: 22
Hey guys, I'm kind of new at this home theater busineess and I had a question about volume. First a little background.
I have a Denon AVR-1905, 2 Polk Rti-4 front speakers, and a Polk PSW 10 sub. I plan on adding a center channel and surround speakers later. My question is this: When watching regular TV or listening to music I usually set the volume on around -35. However, when I watch a DVD movie, I have to set the volume up to around -20 to -15 to really hear, especially the dialogue. Is this just because I don't have a center channel speaker? I did the setup through the receiver and it knows I don't have a center channel speaker. Shouldn't it route all the dialogue through the front speakers? Sorry for the newbie question. I'm sure this is obvious to most of you guys. I would really appreciate some help. Thanks.
Post edited by phileth on
  • hoosier21
    hoosier21 Posts: 4,418
    edited August 2006
    it's not uncommon to have different volume settings for different sources
    don't worry about it
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Skynut
    Skynut Posts: 2,967
    edited August 2006
    My XM radio listening level is around -40
    Cd level -35
    DVD level -30 +
    Normal I think.
    Welcome to the club phileth.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • charliez
    charliez Posts: 72
    edited August 2006
    Hi, you could check your dvd player´s setup. My Sony´s dvd has an audio attenuation feature that I set to off.
    However is not unusual that dvds require more level to sound equal that tv or music.
    Good Luck
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2006
    Welcome Phileth. Yes you will need to boost the volume to hear movies. It's normal.
  • steveinaz
    steveinaz Posts: 19,545
    edited August 2006
    Sometimes DVDP-to-DVDP changes affect this as well. I've noticed that my Denon 2910 takes quite a bit more volume knob than my Panasonic did. Just a difference in output voltage between components.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited August 2006
    How have you connected the DVD to the reciever, analog or digital?
    RT1
  • Willow
    Willow Posts: 11,231
    edited August 2006
    I think it may have something to do the with compression. We do the same while watching movies. Heck even HD TV I boost the volume more than I do reg TV.
  • steveinaz
    edited August 2006
    As a good example, Linkin Park Live in Texas when played thru my Panny required just shy of 12 o'clock volume to rock the house. With the Denon it almost takes 3/4 volume! to reach the same level. (I use analog out).
    It bugs the **** out of me.
  • phileth
    phileth Posts: 22
    edited August 2006
    Thanks for the help. The DVD player is connected with a Toslink cable to the receiver. Video is S-video.
  • adam2434
    adam2434 Posts: 995
    edited August 2006
    Another couple things to try until you get the full surround set-up are
    1) make sure the DVD player's digital out is set to PCM
    or
    2) try using the analog outs from the DVD player
    and
    3) make sure you are listening in stereo mode one the receiver, not any DSP or surround formats.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • aaharvel
    aaharvel Posts: 4,489
    edited August 2006
    seems normal, same on my system. But instead of using straight Dolby Digital (the volume culprit) I either use DTS or if it's a Dolby disc only, try using the "Dolby VS 5ch. Wide" mode if your receiver has it. Imo it's great, ups the volume to DTS quality (surrounds, dialogue, etc.), yet doesn't have the usual DSP characteristics. Meaning- it doesn't sound like $hit.
    Every A/B comparo i've done with it vs. plain Jane Dolby Digital is like night and day.
    "A product with a Dolby Digital/Dolby Virtual Speaker logo decodes 5.1-channel Dolby Digital soundtracks, then applies the Dolby Virtual Speaker process to the multiple channels. Because the soundtrack has already been encoded with Dolby Digital 5.1, each channel is discrete."
    http://www.dolby.com/consumer/technology/virtual_speaker_faq.html
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
