UH-OH. Blown LSiC Driver!
Dang it. In the middle of viewing a movie I smelled something burning and immediately shut down all components. I was afraid the TV was burning up. Nope. Everything looked and smelled fine with the TV. The burning smell dissipated before I could pinpoint where it was coming from. SO.....I cranked back up and couldn't hear the movie dialogue.
Inspection of the LSiC revealed no sound coming from the right-hand (higher-frequency?) driver. That's where the burned smell was coming from, too.
So, my question is.......is this unusual? I've had the LSi's for about a month-and-a-half. The only change I've made was replacing my Onkyo receiver (which I was using as a preamp with an Outlaw 7700 amp) with the Outlaw 990 preamp a few days ago. Been working fine until now. Is there any chance that has anything to do with the LSiC driver blowing?
Crutchfield will ship out a replacement, but the tech support guy said they almost never have any problems with the LSiC. (Of course, I also had to have an LSi25 on the same shipment replaced because the first one's sub was non-functional).
Any thoughts, guys?
(oh.....Cobalt speaker cables and Outlaw interconnects, by the way)
Any thoughts, guys?
Post edited by Altmanfan on
Probably just a random failure. It's a pain to have to wait for a replacement but it beats the hell outta buying a new speaker.
It sounds like the amp is bad / blown channel DC voltage out.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
disneyjoe7 wrote:It sounds like the amp is bad / blown channel DC voltage out.
Sorry to be dense, but I'm sort of a newbie.......it's the amp, not the speaker? -
i think he meant that there may be a problem with that channel on your amp. but it does sound like the center speaker blew like you thought. It happens some times.. my friend cranks his all the time. and had blown two center channel tweeters before.PolkFest 2012, who's going>?
Yes I understand your speaker is bad Sounds like you where sitting down watching a movie, smelling something bad. An amp should only have ac voltage out / never DC (only in small Milli volt range for other electronic tech out there I know) So if the amp channel is blown then yes your driver died also.
Be careful to watch new speaker when you get it replaced if it moves in or out and stays there with no music / audio playing then the amp is given you DC out also // BAD BAD BAD Blown amp.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote:Yes I understand your speaker is bad Sounds like you where sitting down watching a movie, smelling something bad. An amp should only have ac voltage out / never DC (only in small Milli volt range for other electronic tech out there I know) So if the amp channel is blown then yes your driver died also.
Will do.
One more question. The left-hand driver still works perfectly. If the problem was the amp, wouldn't BOTh drivers have gone out, not just the right-hand one? -
Well it depends on how the crossover is designed, so if the left driver has a cap in-line in the crossover then no. The cap will not pass the DC voltage.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I would give Outlaw a call and just run it by them if you are not sure. Their customer service is the absolute best (really) and they will be more than happy to go over any possibilities with you.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Good call Wingnut, I'm wondering about the amp on how that speaker died.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I'll call Outlaw to discuss first thing tomorrow.
As I understand it, the LSiC has a cap in the high-pass crossover, and uses a cascade array to crossover the low-pass drivers at 2400hz and 200hz, respectively. How would that affect DC blockage? -
Thanks for the responses, by the way!
Altmanfan wrote:I'll call Outlaw to discuss first thing tomorrow.
DC direct current is in AC terms 0hz so anything above 0hz is AC / or in our case Audio. Hope this helps
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
You could always hook up the LSic to one of your main channels and see if the drivers all work.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
I would've said that but he needs to check with no music / dead air / nothing and see if drive is forced in / out as I stated before. Caution here because if driver died because of amp then new drive would too if not caught in time.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
