Mantis, got the rsx-1065!
  • polkatese
    polkatese Posts: 6,767
    edited October 2002
    guys,
    the hum goes away...this is what I did, I started with restoring the OSD setup on the 1065 to factory default, and then reconfigured the setting (i.e. assigning the optical output for the DVD and CD) to the 1065 optical output, and voila, hum dissapear...obviously I don't know why it does that, the only think I can suspect, is that the analog loop doesn't like component output, or may be the component out cable (it's a monster M1000CV) is the culprit. Nevertheless, I will need to rework on the setup again next week with the LSi. For the time being, I am content and glad that it got resolved....thanks for your help, fh
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • mantis
    mantis Posts: 17,032
    edited October 2002
    TroyD,
    just for tips......the HTs series has ground loop isolaters built in.When you run cable/dss or Off air antenna threw it, the hums usually goes away.This is something I come across alot.Most hums are grounding problems.
    polkatese,
    glad to see you found your problem, anytime I can help.Enjoy man.
    Dan
  • TroyD
    TroyD Posts: 13,077
    edited October 2002
    Sure Dan, but for less then 50 bucks you can purchase a ground loop isolater, ****, they used to have them in the Polk store. I'm just saying, it's a problem that can be solved inexpensively and in most cases without having to purchase anything.
    BDT
  • joe logston
    joe logston Posts: 882
    edited October 2002
    Dan, I read some of your earlier posting on the merit of speaker cable, 14 awg monster biwire (S14-4) all around should give me more than adequate sound quality, right? fh [/B][/QUOTE]
    my self i think that speaker wire sound the same being the same gage, but there is a differance in sound in interconnect wire so you should experiment with interconnects more than specker wire, its because of the low leval electric out put of the pre amp
    . rt-7 mains
    rt-20p surounds
    cs-400i front center
    cs-350 ls rear center
    2 energy take 5, efects
    2- psw-650 , subs
    1- 15" audiosource sub
    lets all go to the next ces.
  • mantis
    edited October 2002
    They benifit each other in my finding's.Using 14 - 4 all around isn't a bad Idea.
    Dan
  • joe logston
    edited October 2002
    yes, i guess the speaker wire would benifit, but i cant tell if it dose, i can tell on the interconnect wires though, the low level interconnects are more accettable to interfearance & singal loss than specker wire. so a better upgrade to your interconnect wire would bennfit more
    . rt-7 mains
    rt-20p surounds
    2- psw-650 , subs
  • joe logston
    edited October 2002
    i love real good interconnects wires the monster m-1 are good, real good sheilding and connecter ends
    . rt-7 mains
    rt-20p surounds
    2- psw-650 , subs
  • polkatese
    edited October 2002
    Dan,
    attach is a picture of my new baby along with the rest of my other babies, isn't she a beaut, don't you think? :lol::lol: :cool:
  • jrausch
    jrausch Posts: 510
    edited October 2002
    Nice setup!!, Except the center channel is slightly off center.
    "The only way to get rid of a temptation is to yield to it."
  • mantis
    edited October 2002
    Man,
    I just love that peice.The Rotel rsx1065.So give me/us a review how well it mates with the LSI line......I think it's the perfect match.Didn't get the silver one huh.....it doesn't even matter,it could be puple for I would care.....god i love that peice.
    Dan
  • LiquidSound
    LiquidSound Posts: 1,261
    edited October 2002
    Yeah..that would bug the hell outta me. I'd be taking off some of those glass doors above the tv for a center spot.
    Two Channel Main
    Receiver - VSX-54TX
    Mains - Csi40's
    Sub - Spiked Velodyne Cht-8 On Spiked Landscaping Stones
    "If you could put speakers in a needle, I'd never see him again..." - My Girlfriend
  • mantis
    edited October 2002
    Id like to recalibrate the entire system...as well as rewire it.......I see that wireless phone jack back there........We could run a hard wire there.......man how much we could do with your system.......OK when am I invited over?????????????:D ;)
    Dan
  • polkatese
    edited October 2002
    Jraush,
    thanks, I made the mistake during the design of the wall unit, forgetting that I have a center channel, but LiquidSound just gave me an idea to put the LSiC in the right spot....might have to rework the center glass section...
    Dan,
    so far I've been listening on the 5ch mode just on the LSiFx, LSiC, and RM-3000 (front)...and it's two thumbs up, even with the fx set to dipole..basically, the C and the Fx overwhelmed the rm-3000, in terms of tonal quality, dynamic, and openness. And boy, with the 1065, I can pump the volume with no distortion nor hiss. It's amazing, I was watching sting (dvd) - ALL THIS TIME, the instruments sounding out very clean, punchy and full; acoustic bass, trombone, piano..
    I used those wireless phone jack for the directv, I didn't bother to add phone line there cause I don't care so much about making sure that directv keep their tab on my pay-per-view consumption..:lol: but I do need to find an ISF specialist to calibrate the rptv...and your offer sounds very promising! anytime you are in the area, you're welcome to stop by.....
