polk dx 12
Systems
Please spomeone help. Ihave two dx 12'' powered by a kicker zr360. I have switched out the sub on the right side several times because it smells like melting plastic when I push it hard. It can't be the amp cuz they are bridged.
Testing
Testing
Testing
Testing
Testing
Well thats kinda weird that you only have trouble on the right side. Is the airspace shared between the two subs or are they divided? I looked up she specs for the amp, and there within range of the handling of the sub. About all I think to tell you would be to check the wiring within the box, and the sub. How many subs have you gone through on that right side? Try swaping them, and if your still having troulbe, at least you know its not the sub. Hope I oculd be some help to you.
Allerick B.93 Black Acura Legend 6-spd Manual. Soon to be Pioneer Deh-9300 Head Unit Deq-9200 Equalizer and DSP, Streetwire interconnects. PPI PC4400 Chrome(50x4 rms) and PPI PC2400 Chrome (100x2 rms or 400x1) MOMO 6.5" Component Highs up from, Infinity Kappa 6x9's in the rear -
Thanks for the advice I will try it and let you know.
