Solder or No Solder
T-Bone
T-Bone Posts: 24
edited January 2007 in Basic Hookup/Wiring Questions
When installing my ceiling speakers should I solder the connections or no? If yes any special material or instructions?
Post edited by T-Bone on
  • madmax
    madmax Posts: 12,434
    edited July 2006
    I would suggest a good crimp connection on a spade which pushes on the speaker blades. Remember, a crimp is the best connection, solder only keeps it secure.
    madmax
    Vinyl, the final frontier...
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited July 2006
    I'm just curious. Why is a crimp connection the best connection?
  • bknauss
    bknauss Posts: 1,441
    edited July 2006
    There's a difference in resistance (less from crimp) and area that makes contact (more for crimp). I'm not going to say one way or another if it makes an audible difference cause I've never done an A/B comparison.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • WilliamM2
    edited July 2006
    Interesting, I would have thought a proper solder would have more contact, as it fills all the voids, and therefore less resistance.
    Moot point for me, as all my connections are bare wire.
  • AlanD
    AlanD Posts: 32
    edited July 2006
    I was reading that a high-quality crimp (i.e. almost cold welded) is the best approach, but that solder is frequently preferred since it's "easy" to get a good connection. I've A/B'd and have never been able to tell the difference between soldered or crimped connections. I think it's more about convenience.
    F1nut Posts: 51,746
    edited July 2006
    Crimp and solder......best of both worlds.
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2006
    I prefer to have my crimps blessed by a Rabbi wearing an OFC yamulke. There is definetly an audible difference.
  • WilliamM2
    edited July 2006
    Have you compared cables blessed by a Rabbi to cables blessed by a Priest?;)
  • dorokusai
    edited July 2006
    I figured that since I'm not Jewish, that an objective blessing by a different faith would show the largest improvement.
  • happierears
    happierears Posts: 19
    edited January 2007
    the last one i had done was by a Southern Baptist preacher...it did excellent until the next saturday night when it busrt into flames and threw brimstone all over my listening room :mad: :( :eek: :rolleyes: :mad: ......:D #9
