Car Audio Noob
fistofmeat
fistofmeat Posts: 7
okay, i have exerience w/ electronics and wiring, but absolutely none when it comes to car audio installation. i wanna replace the head unit in my car and have no clue how to hook up an amp or sub. also, my left side speaker channels is messed up (when i hook up a speaker to it, i only get static) and my right ones gives me mild static, but i can still hear the music clearly. i wanna know if it's alright to just run a new speaker wire under the carpeting from the head unit, or do i have to hook it up to power. would i have to get andy specific kind of wire? also, i have an old head unit that i never installed, but it doesn't seem to work now, even when i apply the 12 volts to it. is there any way to test it, or should i just throw it away. one more thing. when i buy a new head, do i just hook up power and speakers to it, or is there more to it than that?
thanx for the help guys.
If Life Hand's You Lemons, Throw Them At Someone...
Post edited by fistofmeat on
    F1nut Posts: 51,776
    edited July 2006
    Welcome. You might have better luck by posting in the "On The Move" section.
  • fistofmeat
    fistofmeat Posts: 7
    edited July 2006
    k thanx. this seemed like the right place to put it at first :P
