Harmony Remote Control opinions
cindy100
cindy100 Posts: 256
edited April 2024 in Clubhouse Archives
Hi! I am interested in one of the Harmony remote controls and wanted to get some opinions from here first. I don't need anything fancy or most of all, complicated. I am just tired of having to use 4 different remotes. I have seen some on eBay starting at around $40 which is not bad but also see some priced at $200 & up. If any of you have one and can give your opinions as to whether they really work and how complicated they are to set up, I would appreciate it. Thanks so much for your help.
Cindy
  • PolkThug
    PolkThug Posts: 7,532
    edited June 2006
    They work great. Just write down all your model numbers and what your inputs need to be on for different activities, then login to their website and plug your remote in to your PC with the supplied cable. Just answer the questions on the website, its very easy.
    You can keep it simple or get as fancy as you want. My custom "Demo the Polks" activity will play a certain song on a disc in my changer.
    http://members.harmonyremote.com/EasyZapper/New/Main.asp?WebProcessAction=Start&ClassId=PrNewUser%2EProcNewUser&RelativePath=ProcNewUser%2F&ReturnUrl=%2FEasyZapper%2FNew%2FProcNewUser%2FEnd%2Easp&AccountType=Normal&DealerId=&PackageId=&PackageReturnUrl=
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited June 2006
    Harmony ROCKS baby. :D
    Replaced all remotes with one SWEET.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • cindy100
    cindy100 Posts: 256
    edited June 2006
    Any particular model to stay away from or one you would recommend? Of course there are several to choose from on eBay so...
    Thanks again,
    Cindy
  • disneyjoe7
    edited June 2006
    I own a Harmony 880, it got it for $130 sweet deal like $120 coupon off. It the only one I played with sorry, I think it's a little out of your range.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • PolkThug
    edited June 2006
    I've owned the 659 and the 880. The buttons were much easier to use on the 659.
  • masanz1
    masanz1 Posts: 511
    edited June 2006
    I have the 659. I like it but it seems to eat batteries
    Matthew
    Sometimes the road less traveled is less traveled for a reason
    HT
    Yamaha RX-V2500
    CS400-Center
    SDA 1A-Mains
    RT20-Surround
    None right now-Rears
    SVS 20-39PCi
    Infocus IN72
  • cindy100
    cindy100 Posts: 256
    edited June 2006
    disneyjoe,
    When you say out of my range, do you mean because it is complicated to set up?
    Cindy
  • Willow
    Willow Posts: 11,233
    edited June 2006
    I own a harmony and couldn't be happier. Mind you I have not even tried to modify it to our needs just basic.
  • disneyjoe7
    edited June 2006
    cindy100 wrote:
    disneyjoe,
    Cindy
    Out of your range, only because of your quote for $40 bucks on ebay the 880 retails for $249 I paid only $129 before shipping / handling with a sweet $120 coupon. That was all, it's easy to setup overall.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited June 2006
    For those interested it was from Dell but that coupon is no longer vivid. I will post over here on PF if I see another deal like that, I'm not really sure how often a deal comes up like that. Got wind of this on TivoCommunity.com
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Demiurge
    Demiurge Posts: 10,874
    edited June 2006
    My friend has one, and I just bought one from here. I would say they're a very good remote. The software it comes with is daunting, but don't let that scare you.
  • BIZILL
    BIZILL Posts: 5,432
    edited June 2006
    got me a harmony 659 via club polk karma (thanks again steveinaz!) and have no issues with the batteries. last a good long time for me, and i'm a button-pusher, just ask my ex.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited July 2006
    I love my Harmony remote, I only have 4 devices to control, so I chose the 520, it's quite simple and in my opinion looks mch better than the 6xx series of remotes. The lighting is the best I have seen, very easy to read in the dark, or daylight.
    Even my better half loves it, and she is usually lost when it comes to operating any remote. They are available at Walmart for $98, I got mine off ebay, new for $60 delivered.
    1.jpg 26.8K
    2.jpg 16.7K
  • mutelight
    mutelight Posts: 1,054
    edited July 2006
    I have the 880 and I love it. As long as you know how to access their site and setup your devices it is fairly intuitive. I absolutely love the macro features which will setup all the components of your system for a specific activity. I can't tell you how many times I used to come home to find my gf standing there with static on the screen trying to get a DVD to play.
    Here is a Froogle search result for an idea on pricing.
    // Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
    // Polk Audio FXi A6 // SVS PB12-NSD Subwoofer // Logitech Harmony Ultimate // Pro-Ject Debut III //
    // Oppo BDP-103 // Microsoft Xbox One Day One Edition // Sony Playstation 4 1TB SSHD // Nintendo Wii U //
    Photo Gallery
    Movie and Game Collection
  • disneyjoe7
    edited July 2006
    As long as you know how to access their site, HUH....
    I own one and I'm not sure what the website is and I don't care to know I plug the remote in it makes my computer go to website I log in Done...:cool:
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • mutelight
    edited July 2006
    Sorry I should have said "utilize". Thanks though captain semantics. :cool:
    Photo Gallery
  • disneyjoe7
    edited July 2006
    Thanks, I felt I should clear up any confusion.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • janmike
    janmike Posts: 6,146
    edited July 2006
    Can this remote power on multiple devices with one click. In other words, can you program it to power on the amp, processor, TV and then say the DVDP? Or do I need to use a function button, reference the device and then power each one on individually. I am getting lazy and detest multiple remotes.
    Michael ;)
    NORTH of 60°
  • WilliamM2
    edited July 2006
    It's better than that. It's "activity" based. For example, press "listen to cd" and it powers on all the required gear, and switches to the correct input. Press "watch a DVD, the DVD player powers up, the TV powers up, the correct input is selected, and it even changes the TV to the correct video source.
  • Polkitup2
    Polkitup2 Posts: 1,642
    edited July 2006
    I run a receiver, two amps, two CD payers, a DVD player and a TV with my 880. Couldn't live without it. I push one button and all the needed components fire up and go to the correct settings depending on which activity I want such as watching TV or listening to a SACD.
  • janmike
    edited July 2006
    Sounds great. As for the correct input, my processor automatically takes care of that anyway. Now I need to determine which model (659, 880, 890...)????
    Any other brands that compete with Harmony that are worth look at?
    Michael ;)
    NORTH of 60°
  • Demiurge
    edited July 2006
    Not at that price point. They're the best there. Higher up you get the Pronto, but that's like $300+
  • janmike
    edited July 2006
    Are the older model (pre 880 890) worth looking at? I see the 880 and 890 going for a few hundred.
    Michael ;)
    NORTH of 60°
  • okiepolkie
    okiepolkie Posts: 2,258
    edited July 2006
    Other than the 880 and 890, I would recommend almost any of the their other remotes. Virtually all of them, except the newer 520, 550, and XBox remote, have the same functions.
    I've programmed a slew of 659's, a couple 520's, a 688, and several 880's. For the price, the 659 is a good value. The 688 is my current remote in the living room.
    As far as alternatives, Home Theater Remote(Universal Remote Control) offers remotes that can be programmed more extensivly, however, I still haven't figured out how to program my MX900 to my standards.
    I still don't care much for touch screen remotes. Most of the time, I don't like to look at what I'm pressing, so the feel of hard buttons is better for me.
    Tschüss
    Zach
  • Polkitup2
    edited July 2006
    Okiepolkie, so what is it that you don't like about the 880 and 890?
  • okiepolkie
    edited July 2006
    Actually, I really like the 880 and 890.
    My response, althoughs somewhat ambiguous at the beginning, was trying to answer janmike's question about cheaper Harmony remotes.
    Tschüss
    Zach
  • disneyjoe7
    edited July 2006
    Sorry all, I looked for a discount for the 880 remote but I haven't found one. But overall a sweet remote.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Holydoc
    Holydoc Posts: 1,048
    edited July 2006
    DELL has the 880's on special about once a month. You just have to keep watching them to catch the sales.
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
  • okiepolkie
    edited July 2006
    www.ecost.com has it for $155, which is about as cheap as anywhere else. It is definetly worth that much.
    Tschüss
    Zach
  • disneyjoe7
    edited July 2006
    Thanks guys, I think it worth a link if anyone wishes to own one.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
