Banana plugs won't go all the way in?
barney
barney Posts: 29
Hello everyone
I just bought some banana plugs for my speaker wire today, and it's really hard to get them into the binding post. Am I really supposed to push them in more, because I'm scared of breaking my speakers.
Post edited by barney on
  • Willow
    Willow Posts: 11,231
    edited June 2006
    Don't be scared, it happens, mine do that as well
  • steveinaz
    steveinaz Posts: 19,545
    edited June 2006
    Try rotating them slightly and pushing. Don't push hard.
    F1nut Posts: 51,736
    edited June 2006
    What brand of banana's and what model speakers?
  • danger boy
    danger boy Posts: 15,722
    edited June 2006
    did you remove the banana plug caps on your speakers? the little plastic red and black caps? hee hee hee.
    PolkFest 2012, who's going>?
  • barney
    barney Posts: 29
    edited June 2006
    i have polk monitor 40s and 30s and i used acoustic research screw cap banana plugs. They go mostly all the way in after i tried turning and then pushing, but the tip before the banana plug is cone shaped, so they don't go in all the way (that would be physically impossible).
