Analog question
Humanoid
Humanoid Posts: 27
Hi all, this is my first post and I'm sure it's a newbish question but who cares as long as I learn something.
I have recently, got into the HT seen and want to setup a decent system for movies and music in my living room (14'x20').
I have the cable Top Box connected to the XBR1 via HDMI to HDMI.
Question #1:
I have a Sony upscaling dvd player that can be connected either using component cables or HDMI cable. Currently its connected to the Sony XBR1 via component cables as I felt the HDMI connection was not any better visually. Is this ok, it looks good?
Question#2:
I have the coax from the DVD player connected to the Onkyo 504 receiver for sound during DVD movies/music. The sony DVD player does not have analog inputs. My recent understanding is that the coax cable will not pass hi-resolution audio output is this correct? Is there a better way to hook this up or do I need to dump my DVD player and get one with the inputs? Any recommendations would be appreciated.
TV: Sony KDSR60XBR2
AVR: Marantz SR7002
Mains: Polk RTi8
CTR: Polk CSi5
SS: FXi3
Sub: SVS PB10-NSD
HD DVD: Toshiba HD-XA2
BR DVD: Samsung 1400
Post edited by Humanoid on
  • Skynut
    Skynut Posts: 2,967
    edited June 2006
    1. I use component connections for my DVD as I find it is a better picture than the HDMI.
    2. Coax for the audio is a digital signal going to the avr. The avr then converts it to the 5.1 or 7.1 signal. I use the optical output for my digital signal because I think it offers less possibility for outside interference.
    I do not hear a difference between the coax and the optical.
    A DVD player with analog outputs will convert the 5.1 signal and send it to the AVR. If you have this set up you need to experiment and see if you like the sound of the DVD player or the AVR processing better.
    Edit: welcome to the club.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • Humanoid
    Humanoid Posts: 27
    edited June 2006
    Thanks for the quick reply Skynut.
    So the AVR should have no issues converted the signal via the Coax/optical hookup but, if the DVD player was decoding via analog 5.1 it could diminish the sound quality of the receiver decoding for 6.1-7.1 I would suspect.
    I just didn't want to be miss-out on sound quality with the new speakers.
    This stuff is addicting and even worse than photography. Headed out soon to get the Polk RTi4 for the surrounds.
    Thanks again!
    TV: Sony KDSR60XBR2
    AVR: Marantz SR7002
    Mains: Polk RTi8
    CTR: Polk CSi5
    SS: FXi3
    Sub: SVS PB10-NSD
  • Willow
    Willow Posts: 11,231
    edited June 2006
    As Skynut pointed out I aslo use the component as I prefer it over the HDMI.
    I use coax for my digital connection from HDbox and DVD. I use optical from xbox as it was the only option. Then I use analogue for my cdp.
  • Humanoid
    Humanoid Posts: 27
    edited June 2006
    Thanks Willow!
    I running RCA cables from the HDbox to the AVR. I should probably be using the optical port but I dont have a opt cable yet. Would it make much of a differnce using the optical connection vs. the RCA cables.
    P.S.
    Went to tweeters and picked up the FXi3's instead of the RTi4's. They just sounded better with movie and music to my ears.
    TV: Sony KDSR60XBR2
    AVR: Marantz SR7002
    Mains: Polk RTi8
    CTR: Polk CSi5
    SS: FXi3
    Sub: SVS PB10-NSD
  • Holydoc
    Holydoc Posts: 1,048
    edited June 2006
    Humanoid wrote:
    P.S.
    I am sure you will be very happy with your choice. I like the fact that the FXi3's disperse the sound so well giving the illusion of a very full soundstage.
    Enjoy!
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
  • ward91
    ward91 Posts: 338
    edited June 2006
    with sacd and sometimes dvd-a most dvd players will onley send these formats through analouge outputs (usualy 5.1) and some dvd players dont decode dts so have to send that out through the digital outputs for a external decoder.
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • Humanoid
    Humanoid Posts: 27
    edited June 2006
    Hollydoc:
    I like the setup a lot, though, I could use a better sub but it still sounds very good. I just need to mount my surround rears now to the wall behind the sofa. This means climbing into a very hot attic and pulling a few speaker wires;) Maybe I can get the wifey to do it lol. Not sure if I will go 7.1 or even 6.1 but I will pull the xtra wires while shes up there:D
    ward:
    I have the Sony DVP-NC85H CD/DVD player that has only the HDMI hookup and coax but not any analog hookups. It will decode DTS but looks like Im sol with SACD or DVD-A with it. My receiver (Onkyo TX-SR504) doesn't have HDMI or DVI hookups. I may opt for the new Oppo not sure yet.
    It's my understanding by running through analog cables and playing a SACD or DVD-A, I should up my base settings about +15db as the LFE will not be redirected and the analogs provide a pass-through the receiver. I would love to be able to do this in the DVD players base management options.
    Didn't realize how complicated this can be and I only just started.
    TV: Sony KDSR60XBR2
    AVR: Marantz SR7002
    Mains: Polk RTi8
    CTR: Polk CSi5
    SS: FXi3
    Sub: SVS PB10-NSD
  • higgins79
    higgins79 Posts: 72
    edited June 2006
    if you use rca left and rights from the dvd to the avr your avr should be using dolby pro loigic II wich sounds decent but it is kind of like simulating the surround sound. if you use a dig coax or a fiber optic your avr should be able to kick in dolby digital or dts if the disc has that option (and if your avr has dts decoding) does it sound better? I think so but check it out for your self. you should be able to pick up a decent coax or fiber cable for under $100.
    TV ................Sony kdl52xbr4
    Reciever ........Denon AVR 988
    Amp -............Monster MPA 2250
    Bluray............Sony PS3 (80gig)
    Hddvd............xbox 360 Hddvd
    Power centers.Monster 3600II & 2600II & 1600 x2
    Voltage..........Monster AVS 2000
    Fronts ...........polk Rti12s
    Center ..........polk Csi5
    Rears.............polk Fxi5s
    Sub ..............Infinity PS12
    cables............Monster / DIY
    Video games...XBOX 360 / Wii
  • ward91
    ward91 Posts: 338
    edited June 2006
    just never stops.:D
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
