Newbie Question
REDWING3139
Hello I was hopping some one wouldn't mind explaining to me what you would need for a re amp and amp set up. What I would like to know is what components make up this type of set up. Also what would the proce range be for this set-up. Also what are the Pro's/Cons over just getting and "ALL-in ONE" reciever such.
Post edited by REDWING3139 on
Hello RedWing. Do a search on Preamps & Amplifiers. You will get all the info you need. The seach button is the 3rd on in from the right. Or the 6th one in from the left.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
