what to do with todays a/v receivers with no preout ?
ruffjustice
ruffjustice Posts: 61
i have a onkyo 573 i want a amp hook up but can't todaywith no preouts.what can i get a reasonable amp for about 300. and tuner for f.m any suggestions ? guy's....mike
Post edited by ruffjustice on
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited June 2006
    ruff
    Please, rephrase into the form of a question.. Do you want an amp? Do you want a Receiver, neither, both? I really cant tell.
    RT1
  • steveinaz
    steveinaz Posts: 19,545
    edited June 2006
    I think he's saying he wants to replace his Onk rec with an integated amp and fm tuner...???
  • Sami
    Sami Posts: 4,634
    edited June 2006
    He is talking about A/V receiver so maybe he isn't looking for 2ch integrated. AVR with preouts + 2ch amplifier is my guess.
  • Mike682
    Mike682 Posts: 2,074
    edited June 2006
    Mike, like the others said, please rephrase the above including the thread title
    I'm gonna take a shot here:
    You want an amp and have a budget of $300
    You want to buy a tuner and pay fair market value or you want to buy one from the flea market here.
    As for the thread title, if you can keep the receiver, send it to garage duty or something. Then grab a new receiver w/pre-outs
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • ruffjustice
    edited June 2006
    that is correct guys i want to run about 200-300 watts per 2 channels @ 8 ohms a hook up f.m tuner n a c.d. player thanks in advances ..michael QUOTE=Mike682]Mike, like the others said, please rephrase the above including the thread title
    As for the thread title, if you can keep the receiver, send it to garage duty or something. Then grab a new receiver w/pre-outs[/QUOTE]
  • michael_w
    michael_w Posts: 2,813
    edited June 2006
    Edited... read things wrong. Looks to me like you just want a receiver with preouts and then add a seperate amp or go preamp with tuner section and add an amp? Maybe check out some of the NAD integrateds on the used market, but for that budget you won't get seperates pushing 200-300 wpc... IMO you don't really need anywhere near that power unless you're driving really inefficient speakers. Don't get me wrong, it's great to have headroom and have that extra power, but for normal listening and especially due to the budget I'd recommend not paying a whole lot of attention to wattage ratings. You can do a lot with only a watt or two. That said, what speakers will you be using?
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited June 2006
    Maybe if he would quit being so lazy, and type full words and sentences, it would be easier to figure out what he wants.
    F1nut Posts: 51,770
    edited June 2006
    William, I wouldn't take that bet. Hell, even my decoder ring isn't helping.
